 Post subject: Seagate ST3250823AS 7200.8 recovery
PostPosted: October 24th, 2008, 17:46
I am working with a Seagate ST3250823AS drive right now; the data is not important at all just wanted to get some practice, but I have run into an issue.
The drive originally was clicking; and would not identify. Tested pcb and everything looked good so I figured that the problem was either going to be heads (more likely) or firmware (less likely)
Located and aquired donor; performed head-swap. I have done quite a few head swaps on hitachi, samsung, and toshiba drives but Seagate I do not have much practice with so keep in mind that I was going into this with not much knowledge of seagate internals; I was aware that this model had two platters, four heads.
The head-swap seemingly went very smoothly, but upon completion I loaded the drive up to have it begin clicking again, quieter this time, but still clicking. It will identify now, but attempting to read the media surface, or image the drive produces nothing but clicking. I finally got all set up to be able to read the terminal commands and now have the readout.
Interface task reset
4096k x 16 buffer detected
TONKA - 1_Disk S.00 03-03-05 12:42
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
3.03 03-03-05 12:44
(P)(H)SATA Reset
AutoRd Err 47 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
AutoRd Err 43 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write
SATA core D1 Yuma 6192 No LED Native mode
$Switch to full int.
AM Reacquired
(H)SATA Reset
(S)SATA Reset
$$$Switch to full int.
AM Reacquired
AutoRd Err 47 at ffffffff.00.0081
AutoRd Err 43 at ffffffff.00.0095
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AT Er 00 Nwt Er 47 RdWr 00018.00.0000
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 4118346b ff 4118346b.0.400 0000 0000 adb5 adb4
AutoRd Err 43 at 000018.00.0000
CE Log EC=47 Rtype=25 OV=0 STStatus0
AutoRd Err 43 at ffffffff.00.0081
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
SCAN Error
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AT Er 00 Nwt Er 37 RdWr 1905a.00.00c0
AutoRd Err 43 at 01905a.00.00c0
SCAN Error
AM Reacquired
It continues like that, except sometimes it will spit out that the Niwot timed out?
I am totally new to terminal commands, and have much to learn about them (obviously)
from the looks of what i can understand it seems like the new heads must have been damaged somehow during transfer, which means I certainly need more practice.
My question is are there any other possible things that could be causing this besides damaged heads? ANd what would be the next step to check it.
 Post subject: Re: Seagate ST3250823AS 7200.8 recovery
PostPosted: October 24th, 2008, 19:18
If there is a scratch on a service area it could kill your heads very quickly.
In my personal experience, Seagates often don't click if the head failed.
Take a look at original heads, maybe you will find physical damage on them.
Why do hdd's click?,,,,, because they can't find or read SA. You have to figure out what causing it.
Let me know what you have found.
www.datarecoveryne.com
PostPosted: October 24th, 2008, 22:54
accept above, but one point: that if the head failed the drive will be click sometime.
data recovery service[/b]
PostPosted: October 25th, 2008, 2:08
Not fully compatible heads or Sa scratch. Or both. Unless badly removed/swapped, heads are sufficiently strong, so I vote for problems on the drive.
PostPosted: October 27th, 2008, 13:08
Back in the office; Well, the top platter looks to be ok, but obviously I cannot see below. Since this is only a two platter drive I can use platter extraction tool to pull the platters out and examine the bottom platter, but i cannot see the 2 inside surfaces well. I will let everyone know what I find later today.
PostPosted: October 27th, 2008, 13:21
Users browsing this forum: Bing [Bot], Google [Bot] and 63 guests
