 Post subject: Safe mode for Hitachi SATA drives
PostPosted: October 11th, 2007, 12:06
Anybody knows how to put Hitachi SATA drives in safe mode?
 Post subject: Re: Safe mode for Hitachi SATA drives
PostPosted: November 8th, 2007, 10:31
I have heard that it involves grounding one of the contacts on the logic card. Don't have any exact info.
regards
John - http://www.dq-int.co.uk
PostPosted: October 24th, 2008, 8:16
Anyone know which contact should be grounded? :roll:
PostPosted: October 24th, 2008, 8:43
Which model drive do you have? The process is slightly different for certain drives.
regards
PostPosted: October 24th, 2008, 14:07
What's wrong with connecting the PCB only?
PostPosted: October 27th, 2008, 5:17
HTS721060G9SA00 for example requires a pin to ground to put into safe mode. Most other drives just require the PCB connected as starling suggested.
regards
PostPosted: October 27th, 2008, 6:35
Maybe nothing.... :lol:
Is this the only way to do it?... You know, the guys in the repair factories are a bit lazy, don't like unscrewing screws.... :D
PostPosted: October 27th, 2008, 7:09
If you connect the PCB only PC3000 screws the drive... Could do with a button to stop the process after NVR write.... Then I could connect the bloody PCB to the HDA .....
Users browsing this forum: Google [Bot] and 76 guests
