 Post subject: Maxtor N40P - Bios etc recognize's
PostPosted: November 2nd, 2008, 18:28
Hello everyone.
I have a Maxtor 6E040L0 with thé N40P / NAR6159Z problem.
My bios recognize the hard drive properly. It gives the 40 GB that the HD has..
Windows (Vista) also recognizes the HD (When i first hooked it up in vista it was looking for drivers). The HD is also showing up in Task Manager. Tough it's not showing up in "My Computer".
If i use Seatools, it also recognizes the HD, and all properly with 40 GB..
So i guess (i hope) this is easy to fix because everything recognize's the HD properley with 40 GB ?
What program i should use to fix this?
I'm sorry for my bad English.. I hope it's a little read-able.
I hope someone can help me because i need that HD..
Thanks in advance !
 Post subject: Re: Maxtor N40P - Bios etc recognize's
PostPosted: November 2nd, 2008, 18:40
You can use Pc3000 or Salvation hd doctor for Maxtor. They are hw+sw tools. And of course you know how Maxtor drives work and their firmware. Still thinking it's easy?
PostPosted: November 2nd, 2008, 18:53
Hy DaxDimi,
Your drive have SA corruption / damage.
If you want the HDD, simply forget it.
If you want the data from the hdd, it is a time to seek for some professional help!
Where are you based?
Regards,
Janos
PostPosted: November 2nd, 2008, 19:01
Hmm darn.. I tought it would be easy..
Then nevermind fellas. Thanks for the info so i won't put any useless time / money in it :(.
Also not an option by setting the jumpers in Safe Mode or something ?
PS: Thanks for the fast response..
Greetz
PostPosted: November 3rd, 2008, 2:57
In safe mode your drive won't spin at all. If you either want to have the drive REPAIRED/RECERTIFIED loosing the data or a recovery PM me for details. Can give you a special 'hddguru' offer.
PostPosted: November 3rd, 2008, 14:24
DaxDimi wrote:
Hello everyone.
Thanks in advance !
If drive spins and detects OK, you can see it via device manager, there is option that it's not mapped on your OS. That is just what I get your post. So is the drive formatted to support filesystem that your OS can handle? Is the drive mapped to some letter?
If my computer cannot see drive, it doesn't mean that drive isn't functioning properly.
Just in case... sorry if i'm wrong, but that comes to my mind after that explanation.
PostPosted: November 3rd, 2008, 14:51
pasiz,
This drive changed the FW letter code to NAR6159Z.
This tell as, the SA have some damage, and can't be used.
Only the PCB shows up its native label, like N40P, and the size 40GB, because this is the default in this family.
Regards,
Janos
PostPosted: November 3rd, 2008, 16:05
BTW ... the offer of 'hddguru' special is limited in time... :D
PostPosted: November 3rd, 2008, 17:52
Yeah sorry but don't wanna spend money in it.
Thought i could fix it myself and so learn something, for in the future, if it happens again. Because i readed some people succesfully fixed it.
Greetz
PostPosted: November 3rd, 2008, 23:38
Yeah then use google and search da forum if ya wanna do by yourself cuz we gonna spend much money to learn and do it with expenziv equipment for now and da future. Didn't ya pay some ca$h to go to school? Because ya 'readed' that some people fixed it but don't 'thinked' with what. Greetz.
PostPosted: November 4th, 2008, 2:45
:buhaha: BlackST showing his age :buhahahaha:
PostPosted: November 4th, 2008, 3:55
No, just entered 'kid mode' , reply and click 'exit'... Never too much, though, cuz bad English AIN'T GOOD, LOL !!
PostPosted: November 4th, 2008, 16:51
Kiddie language seemingly harder to learn than english, your doing well with both. ;)
PostPosted: November 8th, 2008, 7:21
N.C. wrote:
pasiz,
Regards,
Janos
Woops, I try to read post completely before answering ;) sorry, my mistake, don't try to remap that drive :(
PostPosted: November 13th, 2008, 14:27
Something puzzling here: you say the drive is recognized as N40P but yet you say it is recognized properly in the BIOS and Windows Vista correctly identifies it as a 40gb drive? This sounds inconsistent with the symptom: normally, when a Maxtor is seen as N40P the drive will not be seen by the OS at all. Please indicate again exactly what BIOS message says.
PostPosted: November 13th, 2008, 22:26
Hi, was reading your post, I had the exact same problem you have.
The firmware on the Surface Area of the platter was corrupted.
I ended up purchasing hard drive recovery tools from Salvation data and was able to recover my data. Some will say I was foolish to spend that amount of money just to recover some data. I don't regret spending the $$$, as I've already done quite a few side recoveries and have reached the halfway point in breaking even.
Let me know if you need some help in recovering the data, I can help you out.
best of luck......
mmmmmm, COOKIES!!!!
PostPosted: November 14th, 2008, 6:45
Sometimes the model is identified correctly, but FW code is abnormal. This sounds like the case here. Professional help is the best advice here. Maybe someone can offer a nice HDDGURU discount, seems to be a lot of them going on here :D
Users browsing this forum: No registered users and 72 guests
