 Post subject: Maxtor 2F040L0 710634 help
PostPosted: November 12th, 2008, 0:00
I have this Maxtor Fireball 3 2F040L0 710634 ABB KFGA
and used a loader I downloaded to load all overlays but the rom fails.
The util starts of the HDD. g-list gives UBR677 Reading error and
SA Surface Verification gives many Maxtor techno command errors.
(the hdd detects with pc3000 with no serial# and VAM51JJZ (0))
I'm not sure if the loader was correct and I'm stuck :oops:
Any ideas?
Can someone help me with the correct firmware (loader) plz.
 Post subject: Re: Maxtor 2F040L0 710634 help
PostPosted: November 12th, 2008, 2:58
Likely you have a Sa problem.
PostPosted: November 12th, 2008, 3:08
yes, SA have bad sector, or you can try other way to write ROM module if you found after writed module don't have any change
data recovery service[/b]
PostPosted: November 12th, 2008, 6:35
SA does have bad. did u check the MOD48?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
Users browsing this forum: No registered users and 66 guests
