 Post subject: WDC ROM MODEL-MAMMOTH—
PostPosted: November 16th, 2008, 4:58
I have WD800BB-00FJA0 its detected as WDC ROM MODEL-MAMMOTH—
I replace the PCB but it's the same and I test the PCB of that's drive on other one the PCB its worked successfully
Then I write service tracks
But it it doesn't work it stay detected as WDC ROM MODEL-MAMMOTH—
Is there any way to repair this hdd
pc 3000 info
Techno mode key:
Tech on................................. : Ok
RAM:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected 51/04 (ABR)
Head number reading..................... : Ok
Heads number............................ : 2
ROM:
ROM reading............................. : Ok
Heads number in use..................... : 2
Switched off heads...................... : No
Head map................................ : 0,1
Service area:
SA dir reading.......................... : Ok (Copy 0)
Configuration reading................... : Module 02 not found
HDD parameters
CONFIGURATION GENERAL INFORMATION:
ATA device
Fixed device and/or controller
Logical cylinders count..................................... 24021
Logical sectors per track................................... 63
Logical heads count......................................... 16
Model....................................................... WDC ROM MODEL-MAMMOTH--
Serial number............................................... WDC-ROM SN# XYZ----
Firmware.................................................... 13.03G13
Maximal block size for READ/WRITE MULTIPLE commands......... 16
Features
Stop Timer Value
IORDY............................................. Supported
LBA Mode.......................................... Supported
DMA Mode.......................................... Supported
Current Logical Parameters
Cylinders......................................... 24 021
Heads............................................. 16
Sectors........................................... 63
Capacity.......................................... 24 213 168 Sectors (11 822.8 Mb)
Capacity available in LBA Mode.................... 156 332 737 Sectors (76 334.3 Mb)
Capacity available in LBA 48 Mode................. 156 332 737 Sectors (76 334.3 Mb)
Available DMA Mode
Multiword DMA Mode 0
Multiword DMA Mode 1
Multiword DMA Mode 2
Active DMA Mode............................................. Multiword DMA Mode 2
Active UDMA/33 modes
Ultra DMA/33 Mode 0
Ultra DMA/33 Mode 1
Ultra DMA/33 Mode 2
Ultra DMA/33 Mode 3
Ultra DMA/33 Mode 4
Ultra DMA/33 Mode 5
Current UDMA/33 mode........................................ [none]
Current PIO mode
Supported Enhanced PIO Modes
PIO MODE 3
PIO MODE 4
Minimal multiword DMA cycle time............................ 120 ns
Recommended multiword DMA cycle time........................ 120 ns
Minimal multiword PIO cycle time w/o stream control......... 120 ns
Minimal multiword PIO cycle time with IORDY................. 120 ns
Supported standards
ATA - 3
ATA - 4
ATA - 5
ATA - 6
Supported Command Sets
S.M.A.R.T functions
Security system............................................. Not supported
condition flags :
password set...................................... NO
HDD Locked........................................ NO
HDD Frozen........................................ NO
wrong password count exceeded..................... NO
security erase support............................ NO
security level.................................... HIGH
Master code................................................. 0000
 Post subject: Re: WDC ROM MODEL-MAMMOTH—
PostPosted: November 16th, 2008, 7:16
Configuration not found... Are the rom fully compatible? Did you write service tracks correctly?
PostPosted: November 16th, 2008, 10:23
this is SA problem and i remember this forum have mention about this topic. you can search it.
data recovery service[/b]
PostPosted: November 17th, 2008, 3:37
