 Post subject: Terminal log
PostPosted: November 26th, 2008, 9:39
Hi to all!
Error is hdd ST9160821AS
Look:
Reset
4096k x 16 DRAM
VENUS - 1_Disk M-37 12-01-06_14:56
Buzz HM SFI
ERR Read Boot Adapts
Thanks advanced!!
Нет ничего невозможного
 Post subject: Re: Terminal log
PostPosted: November 26th, 2008, 12:32
might be weak heads (most probably) or damaged adaptives...
PostPosted: November 27th, 2008, 15:08
I vote for heads .
PostPosted: November 27th, 2008, 22:42
hello,
have you try to swap the PCB?
data recovery service[/b]
PostPosted: November 28th, 2008, 3:31
yeah, one more chance: pcb is not the native one.
PostPosted: November 28th, 2008, 14:05
I dont think it could be pcb issue if it was the output would have been about APP code .
PostPosted: November 28th, 2008, 16:42
If somebody messed up the PCBs and Sempre received it with non native PCB, the drive can seek the SA in a different position, so it cannot read boot adapts from there either...
PostPosted: December 8th, 2008, 16:35
networkpc3000 wrote:
hello,
For exchange of pcb which details must be identical? (FW, MODEL,)
:mrgreen:
PostPosted: December 8th, 2008, 18:27
Check the numbers on pcb, and tried to find similar PCB Matching microcontroller and read channel, did u check if PCB its from patient HDA Sempre?
PostPosted: December 9th, 2008, 8:08
Thanks my friend!!
I verify and post result in forum!! :mrgreen:
PostPosted: December 15th, 2008, 14:54
HEADS GOOD!
:mrgreen:
PostPosted: December 16th, 2008, 9:45
Hi to all!
in pci ver 2.21 and 2.27 not and compatible with model ? (ST9160821AS VENUS)
:shock:
PostPosted: December 17th, 2008, 13:11
sempre wrote:
Hi to all!
:shock:
It has some possibility to use a utilitarian one of one another model to read the FW? :?:
:idea:
:mrgreen:
Users browsing this forum: Google [Bot] and 72 guests
