 Post subject: Dust on plate
PostPosted: November 26th, 2008, 14:13
can i remove with a photographer pump brush some dust created on the surface of plate ( into a clean room obviously)?
thx
 Post subject: Re: Dust on plate
PostPosted: November 26th, 2008, 14:14
use a can of compressed air.
PostPosted: November 26th, 2008, 15:15
wich kind of dust is it ? some times the hdd when head crash, at the moment when heads shocks with platters the MR sensors from heads are burned from the impact and u can see that dust over platters
PostPosted: November 26th, 2008, 17:31
if you opened the drive and there is dust inside
your find out that somewhere on the platter possible damaged
by the headstack touching it.
if not you can use compress air or infact works well is a photographer pump brush
Users browsing this forum: Majestic-12 [Bot] and 87 guests
