 Post subject: Best software for hdd repair (erase delays, bad sectors...)
PostPosted: November 27th, 2008, 17:38
Hello, I am using mhdd to test and repair my hard drives, but, I was thinking...maybe I can use some better program to do that kind of things??
I use it to erase delays, repair bad sectors...and not much more.
Any recomendations??
Thanks a lot.
 Post subject: Re: Best software for hdd repair (erase delays, bad sectors...)
PostPosted: November 27th, 2008, 22:31
that is the best one i think that around.
not sure if a hard drive can repair bad sectors at all
its more likely just cliping it so it does not put any data on there
PostPosted: November 28th, 2008, 3:10
Need hw/sw tools and work with err list or start internal selfscan and fix it completely. But it will cost you thousand $...
PostPosted: November 29th, 2008, 5:19
Using MHDD I have the sense of that it pass by each sector but don't clip it, becouse I see always almost the same sectors in every lap, usind loop test and erase time delays...
Im doing something wrong??
PostPosted: November 29th, 2008, 17:29
No, simply your problem is beyond the possibilities of a free software. That's all.
Users browsing this forum: Google [Bot] and 90 guests
