 Post subject: [Logical error] IDE disk detected by BIOS but not in OS.
PostPosted: November 27th, 2008, 11:35
Not just any not detected problem.
I suspect the drive is on the verge of a catastrophic failure, and was about to pull everything off it when it gave me the classic disk-not-formatted error. I shutdown immediately and pulled it out. Yesterday I bought Recover My Files software to try to uh.. recover my files. However, although the disk is detected in Award BIOS (albeit showing 100% free space but I'm dead sure the data's still there and has not been overwritten), it does not show up in either Explorer, Device Manager or Disk Management. Also tried Knoppix on LiveCD to run DDrescue or TestDisk but not detected either.
[At this point I thought of reformatting the drive to make XP recognize it since the software can recover files from a lost partition.]
But realized couldn't since it wasn't even showing up in Disk Management (unformatted disks can be detected and formatted from there). Neither did my faulty drive show up in Windows XP Setup.
I'm quite sure the drive is not suffering from any mechanical failure (yet). It's just that for now I have no idea how to get the stuff off it. There is the occasional clicking sound as well in about 45-minute intervals (hence the trying-to-backup).
Would prefer a quick reply as I need the data quick. Posted in another forum but response was disappointing - disgusting nerds, the whole bunch of them.
Cheerio,
Nicholas. :|
 Post subject: Re: [Logical error] IDE disk detected by BIOS but not in OS.
PostPosted: November 27th, 2008, 11:45
Post Drive Info. Brand, model n how its detected in BIOS...
Scan using MHDD if sectors could be read.
If clicking sound, never attempt any task, meet to pro directly.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: November 27th, 2008, 12:19
Is it recognised properly in the BIOS (i.e. Proper model number and capacity)?
Sean
PostPosted: November 27th, 2008, 12:36
DiamondMax Plus 9 6Y080L0130413 IDE/80GB. No OS. Secondary storage. Award BIOS reports correct drive model, but displays an empty capacity when the drive is supposed to be nearly full.
Edit- no clicking sound either, threw up a not-formatted error and left it alone until now.
Cheerio,
Nicholas.
PostPosted: November 27th, 2008, 12:58
Its SA if capacity displays 0. No end user solution.
__________
THANK YOU
SHAHI
PostPosted: November 27th, 2008, 12:59
SA?
No, capacity is described as 80GB free.
PostPosted: November 27th, 2008, 13:02
nicky9499 wrote:
SA?
Ok, scan with MHDD few sectors n post report
__________
THANK YOU
SHAHI
MHDD? Please elaborate on procedure? Can get it done and post results immediately.
PostPosted: November 27th, 2008, 22:32
hello,
you can find out it here.
http://hddguru.com/content/en/software/2005.10.02-MHDD/
data recovery service[/b]
PostPosted: November 27th, 2008, 22:50
sa aka service area of the drive is corrupted or damaged.
PostPosted: November 28th, 2008, 1:45
The drive is being detected now as MAXTOR CALYPSO in BIOS with 0MB capacity despite shahij's attempts to help me last night, albeit much appreciated.
It turns out that the reason why it's being detected as CALYPSO is because of a corrupted firmware (how it got corrupted while sitting in a corner of my room I don't know).
References:
http://www.dataclinic.co.uk/bios-codes- ... d-disk.htm
Right now, given the model and serial number, can anyone give advice on how to flash the correct firmware to the hard disk and thereafter which recovery efforts can be continued?
edit-
As of now the machine hangs right after BIOS detects all drives correctly (with the exception of that CALYPSO crap). Can only boot into Knoppix using LiveCD.
Cheerio,
Nicholas.
PostPosted: November 28th, 2008, 2:06
Update: Computer won't boot, even after BIOS reset and removing all IDE/SATA devices. Has this turned into a motherboard problem as well?
PostPosted: November 28th, 2008, 2:37
Boots fine into Knoppix off LiveCD after starting with bootable pen disk plugged in. As it is, I still want to know how to properly flash firmware to faulty hard drive.
Cheerio,
Nicholas.
PostPosted: November 28th, 2008, 3:04
Flash? It's not a cell phone or mp3 player.
PostPosted: November 28th, 2008, 3:09
I have applied modified firmware to region-locked DVD drives before. So whatever that process is called, I just want to know where to find the firmware for my particular drive and procedures for applying it.
PostPosted: November 28th, 2008, 3:15
The 'Corrupted Firmware' you found mention to is the SA. As BlackST referred to, it's not fixable without expensive tools. It's not like you can just download a patch from Seagate and flash the firmware. There are relatively cheap tools available (Salvation), but they likely cost as much as the help of a Professional, and don't come with the knowledge or experience. When the solution is within reach, I'm happy to tell someone. This isn't one of those times, and the bad news is that it will cost money to retrieve the data.
PostPosted: November 28th, 2008, 3:17
So, it isn't possible to apply new firmware to hard drives like any other device?
Oh well, since you say so, then I guess it can't be helped. :(
Thanks to all,
Nicholas.
PostPosted: November 28th, 2008, 3:19
It's not like flashing a DVD either. Also, to save another question, and some of your time, fixing the SA requires a hardware/software combination. You won't find some cracked program that will magically fix your drive.
PostPosted: November 28th, 2008, 3:20
Nono, I wasn't thinking about that. But thanks for the advice.
PostPosted: November 28th, 2008, 4:47
If you need the data quick you have no choice but to spend some money.
