 Post subject: Help!!! need to recover from old WD-387T 60MB drive
PostPosted: December 4th, 2008, 20:01
Hi guys, does anyone here recognize this drive. What I want to know is what kind of connector do I need to even plug this drive with motherboard? Any help or suggestion would be appreciated. see attached pics.
 Post subject: Re: Help!!! need to recover from old WD-387T 60MB drive
PostPosted: December 4th, 2008, 20:18
I think that is a ESDI connector.
http://www.vp-webdesigns.com/vpe/TSU/HAR.htm
Good Luck!
PostPosted: December 4th, 2008, 20:53
Yep, ESDI... You'll need a special controller for it. I see some old ISA ESDI controllers on ebay for pretty cheap.
PostPosted: December 5th, 2008, 3:43
if it hasn't been used for a long time it will probably have stiction (Heads stuck to platter inside), quite typical on these old beasts
Hope all goes well
PostPosted: December 5th, 2008, 11:25
Thank you guys for your input, glad I did not waste too much time on this one. Client changed their mind and decided not to recover data after all.
Users browsing this forum: Google [Bot] and 76 guests
