 Post subject: PGP imaged data locked by password
PostPosted: December 4th, 2008, 22:45
Anyone know or possible to unlock PGP locked image data?
Thank you.
 Post subject: Re: PGP imaged data locked by password
PostPosted: December 5th, 2008, 5:11
do you know the password?
PostPosted: December 5th, 2008, 5:46
no, passkey and any other clues related to passwd are unknown.
PostPosted: December 5th, 2008, 7:33
Maybe in a million year with bruteforce... :)
PostPosted: December 5th, 2008, 22:01
i got the same with TerraNove
here is the 3FH
maybe somebody have an idea..
Спасибо
СУТИОНО / АПИНГ
PostPosted: December 5th, 2008, 22:15
w/o password you screwed. It's unbreakable in reasonable period of time
Why don't you ask client for password?
PostPosted: December 5th, 2008, 22:21
Yep, (Pretty Good Privacy) is pretty good :lol:
PostPosted: December 5th, 2008, 23:27
I guess if someone can crack this deserves to be called "The enlightened GURU" :D
PostPosted: December 5th, 2008, 23:49
ithere is no magic supermegacoolpassword which opens all the doors
the only way is bruteforce
PostPosted: December 6th, 2008, 0:02
Agreed. There is no such thing as unbreakable. Only that it will take so long, that it will be pointless. There are some encryption schemes that have been cracked (meaning flawed mathematically-speaking), however, modern PGP is not one of those.
You're only hope (since there is no PUBLICLY known method) is to search for keyring. In investigative work, this is usually done by forensic analysis and/or use of trojans and/or keyloggers. With the pwd it is hopeless. PGP and similar encryption schemes employ 128-bit min. mechanisms, and government agencies around the world have, themselves, been unable to prosecute suspects whom encrypted their data using PGP.
http://pcrecoveryllc.com
PostPosted: December 6th, 2008, 0:23
The good thing about it you don't need to break 128-bit key
You just need to break password which usually consists of letters and digits and not longer than 6-8 chars
PGP hashes user-entered-password into 128-bit key. Hash algorithm is not a secret
PostPosted: December 6th, 2008, 1:53
Usually I will send the original image back to client if they do not want to tell the password.
i got no idea without the password
They can decrypt by themself :)
Спасибо
СУТИОНО / АПИНГ
PostPosted: December 6th, 2008, 3:28
the answer is nope your screwed as the pgp is very secure.
the only people who can crack this is the nsa
PostPosted: December 6th, 2008, 4:22
Really sure? Pgp is documented. Oh, by the way, quad core pcs are cheaper today, so... (it is a clue)
PostPosted: December 6th, 2008, 7:56
I think this is pointsec rather than PGP the _BGKEY_ signature indicates this.
You will need to get a boot floppy from the customer with the key. When you run this you will be asked for a login and password and then a final confirmation. then the drive will decrpyt..
pointsec T Support are usually very good and will explain how it is done. But you will need the boot floppy from the customer. Pointsec uses AES (probably 256).
https://www.mjm.co.uk/
Users browsing this forum: Google [Bot] and 106 guests
