 Post subject: Samsung SP2514N Platters Moter Stack
PostPosted: January 2nd, 2009, 7:05
Model:Samsung SP2514N ,250GB ,7200,8M, PATA.
After the drive fallen down is from External Lacie Box the moter stack (like Seagate External Drive Cases).
The problem is how i can remove the platters from the drive , because i have 2 platters with one aluminum divider inside.
Take a look at below pics and you can understand
[img]http://rafaela.vsrcbd.com/IMG_0158.jpg
[/img]
[img]http://rafaela.vsrcbd.com/IMG_0159.jpg
[/img]
[img]http://rafaela.vsrcbd.com/IMG_0166.jpg
[/img]
The other way is to remove the moter (but until now i don't have that tool)
Thanks in advance
Xronis Kyriklakis
T3 Professional Data Recovery
http://www.t3-recovery.com
 Post subject: Re: Samsung SP2514N Platters Moter Stack
PostPosted: January 2nd, 2009, 7:19
By opening it, you already contaminated the platters. You can see lots of dust and a possible finger print in the pics. Close it up and send it to a pro if its worth anything.
PostPosted: January 2nd, 2009, 8:09
We are Pro and the drive is come all ready opened , left the dust and look the devide solution.
PostPosted: January 2nd, 2009, 8:20
I confirm : they are PROS.
Check MSN :D
PostPosted: January 2nd, 2009, 8:32
This problem was encountered previously by sempre or other member of this forum (as I recall). The solution I can think of , is the same as handling Seagate multi platters with spacer, use SD platter extractor tool and modify a little and with some creativity to maintain the alignment of lower and upper cylinders.
My Forum
PostPosted: January 2nd, 2009, 8:49
this is a good answer cryoborgofthevenus
PostPosted: January 2nd, 2009, 9:11
Like "Horse" says Samsung want to give some pain in the ass, and in the ............ to DR specialists.
PostPosted: January 2nd, 2009, 9:24
U can also remove the platters one by one and realign them in the new chassis, but this is very hard to do.
I have developed a much better solution than the SD toolset but I won't disclose it on an open forum of course.
PostPosted: January 2nd, 2009, 9:32
That's what I told him. Difficult but not impossible, for me usually works.
PostPosted: January 2nd, 2009, 9:37
needs some patience :) and time...
that's why I chose to figure out something else.
PostPosted: January 2nd, 2009, 14:09
From my experience Samsungs of that model are easy even with platters transplant
If you are a pro you should know how to deal with drives with separators
But apparently you are not
PostPosted: January 2nd, 2009, 14:25
2 platters could not be extracted at a time to the drive. thats why, mis alignment is seems going on. Its a complex case, not easy.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: January 2nd, 2009, 14:47
Wanna bet?
PostPosted: January 2nd, 2009, 14:48
If you say so
PostPosted: January 2nd, 2009, 15:16
Shahij... even 4 platters CAN be extracted together without loosing alignment.... of course it depends on the tool and on who is doing the job. Trust me ;)
PostPosted: January 2nd, 2009, 16:01
agree this way, well answer, and it need patience to do it. every problem using easy way to solve, don't think more. that was PRO DR
data recovery service[/b]
PostPosted: January 2nd, 2009, 16:36
My hobby is numismatics - http://coins.zoxt.net/
Doomer from now on we can learn from you Pro + Class
PostPosted: January 3rd, 2009, 3:26
Ya, agree.
But, I m telling about the specific drive where divider (aluminium) is placed between platters. Please re look on the drive pictures.
__________
THANK YOU
SHAHI
PostPosted: January 3rd, 2009, 4:05
@shahij :
First, Imagine the drive without the aluminium divider. Now extracting those platters become easy.... :D
How ? You will figure it out, friend.
My Forum
PostPosted: January 3rd, 2009, 4:31
Already given to whom it concerns details on what to do... Let's go back to our cleanrooms, guys ! !
Users browsing this forum: No registered users and 70 guests
