look for controller board wd3000jd
February 17th, 2009, 10:05
hi ,my controller board hd wd3000jd was broken im looking for,please help me about this
thanks
Re: look for controller board wd3000jd
February 17th, 2009, 10:46
Need a full model number of the drive or a board number.
February 17th, 2009, 15:13
why ? what is the difference
February 17th, 2009, 20:02
They all have different PCBs. If it's not the right part number then it won't work. I have plenty of WD PCBs that I'll be happy to sell you if you just want a random one. If you want one that will have any chance of working whatsoever, you will need to supply the part number from the PCB.
February 26th, 2009, 18:56
the full number is wd3000jd-98klbo LBA 586072368
February 26th, 2009, 18:57
March 1st, 2009, 6:36
Number on the pcb as well eg 2060-xxxx--xxx
March 12th, 2009, 18:01
i have an other number : 2061-701336-b00 ab
