 Post subject: Apple drives compatability
PostPosted: January 12th, 2009, 6:29
Hi all
A quick question.
I have several hard drives from seagate in 2.5 and 3.5 inch that require donor boards and heads. these drives are specifically marked with an apple log on them.
Is it nescessary to match the donors with an exact drive with an apple log or wil the usual matching of firmware, sitecode model be sufficent.
thank you
 Post subject: Re: Apple drives compatability
PostPosted: January 12th, 2009, 6:42
What models are you specifically talking about? In my experience with seagates the drives do not need to be exaxctly identical. Just the same donor requirements as seagates without the apple logo.
PostPosted: January 12th, 2009, 7:02
Hi hddguy
thank you for the reply
there are 2 drives in particular
1 is 7200.7 ST3160023AS fw 5.06 site amk
other is monentus St 9100823A
fw 3.06
site amk
they both have apple logos printed on them
so i should be able to look for a donor where i match as per instructions on the site with fw and country and should be ok?
thank you
PostPosted: January 12th, 2009, 18:55
If you match FW and country on Momentus you should be OK, in my experience.
http://www.datasaversllc.com
PostPosted: January 13th, 2009, 3:53
Agree. If you encounter major differencies or issues let us know. Interesting.
PostPosted: January 13th, 2009, 10:18
Just match the usual for either head swap or pcb and should work. the apple logo is only on there as they were bought by apple to use in new computers
PostPosted: January 13th, 2009, 10:44
macman, you really are the guru of all guru's :lol:
Users browsing this forum: No registered users and 72 guests
