 Post subject: ST380011A not recognize in bios
PostPosted: January 20th, 2009, 18:55
Hi, all,
my hdd bios could not recognize, its something like that ""?!?"?#?"??!$#SA?D?AS?"!"", but i manage to connect through terminal..
There is no commands like this on new series..
Can anybody pinpoint me, what i need to search/repair,What module..or something...
nad commnads,list of commands..
Bye
 Post subject: Re: ST380011A not recognize in bios
PostPosted: January 20th, 2009, 19:00
Could be bad connection on PCB, or bad PCB.
PostPosted: January 21st, 2009, 3:35
Check your interface cable as well. And if you have secondary IDE try to connect it there too.
DataRecovery.bg
PostPosted: January 21st, 2009, 7:43
I have to agree with Samo, check your SATA/IDE cable
PostPosted: January 21st, 2009, 12:28
When HDD is cold, bios, recognizse him, but when it warms up this become "djkansd?=#$"=$#"?$?""
So you think, that this is PCB, IDE cabel is ok, not FIRMWARE or something 100% ?
PostPosted: January 21st, 2009, 14:04
We can't be sure just suppose, to be 100% sure you must test it with other PC.
I've seen as bad PCB, as bad cable and bad MB as well that cause same error as you describe.
So probably for you will be easier to test the parts before start to search for suitable PCB.
DataRecovery.bg
PostPosted: January 21st, 2009, 14:10
I vote for pcb , also check for broken pins on IDE connector .
PostPosted: January 21st, 2009, 14:31
Yeah, for about 3 years ago, when hdd shows first signs of failure, i put them to the freezer ,then i connect him to motheboard,and start coping the data to another hdd...:=)
PCB, must be same firmware? 3.04?
PostPosted: January 21st, 2009, 17:32
I try to work with this program, i connect to com1, but when i select script adn hit "run" nothing happend!!
why..?
with hyper terminal i get status from hdd and everything is ok...
T>Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Head Mask 000F - Switch to full int.
Spin Ready
3.04 09-10-03 10:10
(P)PATA Reset
Master
T>
T>
PostPosted: January 21st, 2009, 18:16
Looks fine but If reach´s level T> u should be check for "Age"= 50 and " Ready " Status LBA xxxx another way u could use MHDD, check for "passport" DRDY DSC registers, and run ,a read sector test, to know if its possible to read sectors without problem, if no could be send ABRT
PostPosted: January 21st, 2009, 18:52
CONNECTED TO SERIAL PORT \\.\COM1 (9600-8N1)
Buzz - Head Mask 000F - Switch to full int.
Spin Ready
3.04 09-10-03 10:10
(P)PATA Reset
Master
T>
T>
T>ALPINE - 1_Disk 3.04 09-10-03 10:10
Built for ALPINE,GRAND2,Diamondback,TI1761 PreAmp,STL6 Andante PreAmp,InternalSpin,GC110,SVC123AC,OneToOne,2Disk,LowDelta,220 Servos,7200RPM,8Pole,NonModGray,100MHz,Code DRAM,Early Exit,Stall Converter,RwFeat=0000,SeaDex,MDW
T> VALID Cert Disk Code Detected - Revision # .133
T>
T>Pgm=00 Trk=0EDD7(0EE57).0(0).240(000) Zn=9 Err=00 ErCt=0000 Hlth=0018 CHlth=0000 Ready LBA=00000000
T>
Age Typ Hds Lent Loopcnt TrkGn Thld Grey Intg TrkOfst SpnIntg
50 21 1 0000 0000000 0028 00F73A FDB7 0000 1919
:5000001821000001 AX`3JV6A94R' "000000000000"0EDAB-0EE2A
SRAM Ovly = Diag
T>
RD:0200:10
WR:0210:10
AC:022B:01FF
AS:042A:0065
SC:048F:0201
DP:022B:01FF
BA:0227:03
ST:022A:01
logbps:0200
codebps:0200
uP:0FE2:1E
FM:0220:07
AD:0220:0B
RL:0FDD
SL:0F1A
AL:0F03
MZ:0FF6
T>
T>k
Command Inactive - No VALID Cert Code Detected
T>y
T>&
T>/2
2>x
Zone 00: 00018 - 00BE8 1100 (044C) 683.439
Zone 01: 00BE9 - 027FE 1056 (0420) 666.63
Zone 02: 027FF - 04707 1026 (0402) 646.275
Zone 03: 04708 - 06CA3 990 (03DE) 622.431
Zone 04: 06CA4 - 08B66 953 (03B9) 602.353
Zone 05: 08B67 - 0A479 916 (0394) 580.392
Zone 06: 0A47A - 0C405 880 (0370) 545.882
Zone 07: 0C406 - 0D99A 836 (0344) 527.59
Zone 08: 0D99B - 0ECD9 806 (0326) 506.144
Zone 09: 0ECDA - 10337 770 (0302) 480.724
Zone 0A: 10338 - 11397 733 (02DD) 461.672
Zone 0B: 11398 - 12854 691 (02B3) 437.423
Zone 0C: 12855 - 13F38 660 (0294) 410.353
Zone 0D: 13F39 - 14AE7 623 (026F) 396.401
Zone 0E: 14AE8 - 155D6 605 (025D) 383.316
Zone 0F: 155D7 - 16358 572 (023C) 363.922
Sys= 0EDAB-0EE2A 0280 SPTK on sys trks
Total LBAs = 095333FC
2>
2>/0
T>D4E
Cert Table loaded
og 4E - Health 0018 - HlthDtl 0001 - Cert Rev = R130 - Rom Rev = 3.06.m61 - Time = 00:00:09 Log Type = 01
Log 02 - Health 0008 - HlthDtl 0000 - Time = 00:44:58 Log Type = 01
Log 03 - Health 0010 - HlthDtl 0000 - Time = 00:02:10 Log Type = 01
Log 04 - Health 0000 - HlthDtl 0000 - Time = 00:01:34 Log Type = 01
Log 05 - Health 0000 - HlthDtl 0000 - Time = 00:00:12 Log Type = 01
Log 06 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 07 - Health 0000 - HlthDtl 0000 - Time = 00:00:03 Log Type = 01
Log 10 - Health 0000 - HlthDtl 0000 - Time = 00:07:58 Log Type = 01
Log 11 - Health 0000 - HlthDtl 0000 - Time = 00:05:45 Log Type = 01
Log 12 - Health 0000 - HlthDtl 0000 - Time = 00:05:49 Log Type = 01
Log 13 - Health 0000 - HlthDtl 0000 - Time = 00:05:45 Log Type = 01
Log 14 - Health 0000 - HlthDtl 0000 - Time = 00:05:46 Log Type = 01
Log 15 - Health 0000 - HlthDtl 0000 - Time = 00:05:53 Log Type = 01
Log 16 - Health 0000 - HlthDtl 0000 - Time = 00:05:51 Log Type = 01
Log 17 - Health 0000 - HlthDtl 0000 - Time = 00:08:01 Log Type = 01
Log 18 - Health 0000 - HlthDtl 0000 - Time = 00:05:54 Log Type = 01
Log 19 - Health 0000 - HlthDtl 0000 - Time = 00:05:55 Log Type = 01
Log 1A - Health 0000 - HlthDtl 0000 - Time = 00:05:55 Log Type = 01
Log 1B - Health 0000 - HlthDtl 0000 - Time = 00:05:46 Log Type = 01
Log 1C - Health 0000 - HlthDtl 0000 - Time = 00:05:45 Log Type = 01
Log 1D - Health 0000 - HlthDtl 0000 - Time = 00:05:43 Log Type = 01
Log 1E - Health 0000 - HlthDtl 0000 - Time = 00:05:51 Log Type = 01
Log 2A - Health 0000 - HlthDtl 0000 - Time = 00:10:22 Log Type = 01
Log 1F - Health 0000 - HlthDtl 0000 - Time = 00:00:06 Log Type = 01
Log 2F - Health 0000 - HlthDtl 0000 - Time = 00:00:05 Log Type = 01
Log 0B - Health 0000 - HlthDtl 0000 - Time = 00:00:11 Log Type = 01
Log 09 - Health 0000 - HlthDtl 0000 - Time = 00:04:56 Log Type = 01
Log 58 - Health 0000 - HlthDtl 0000 - Time = 00:03:34 Log Type = 01
Log 21 - Health 0000 - HlthDtl 0000 - Time = 00:03:54 Log Type = 01
Log 08 - Health 0000 - HlthDtl 0000 - Time = 02:29:12 Log Type = 02
Log 0A - Health 0000 - HlthDtl 0000 - Time = 00:02:42 Log Type = 01
Log 0C - Health 0000 - HlthDtl 0000 - Time = 00:45:31 Log Type = 02
Log 0F - Health 0000 - HlthDtl 0000 - Time = 00:04:58 Log Type = 01
Log 0E - Health 0000 - HlthDtl 0000 - Time = 00:00:40 Log Type = 02
Log 0D - Health 0000 - HlthDtl 0000 - Time = 00:00:26 Log Type = 01
Log 40 - Health 0000 - HlthDtl 0000 - Time = 00:54:32 Log Type = 01
Log 25 - Health 0000 - HlthDtl 0000 - Time = 00:03:59 Log Type = 01
Log 31 - Health 0000 - HlthDtl 0000 - Time = 01:06:58 Log Type = 04
Log 32 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 04
Log 33 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 04
Log 34 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 04
Log 36 - Health 0000 - HlthDtl 0000 - Time = 00:20:05 Log Type = 02
Log 37 - Health 0000 - HlthDtl 0000 - Time = 00:00:04 Log Type = 02
Log 26 - Health 0000 - HlthDtl 0000 - Time = 00:11:35 Log Type = 01
Log 3A - Health 0000 - HlthDtl 0000 - Time = 01:51:46 Log Type = 02
Log 38 - Health 0000 - HlthDtl 0000 - Time = 01:26:03 Log Type = 02
Log 3B - Health 0000 - HlthDtl 0000 - Time = 00:07:56 Log Type = 02
Log 3C - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 02
Log 3D - Health 0000 - HlthDtl 0000 - Time = 00:00:04 Log Type = 01
Log 3E - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 02
Log 3F - Health 0000 - HlthDtl 0000 - Time = 00:00:33 Log Type = 01
Log 42 - Health 0000 - HlthDtl 0000 - Time = 00:02:48 Log Type = 01
Log 43 - Health 0000 - HlthDtl 0000 - Time = 00:06:25 Log Type = 01
Log 20 - Health 0000 - HlthDtl 0000 - Time = 00:11:31 Log Type = 01
Log 47 - Health 0000 - HlthDtl 0000 - Time = 00:05:32 Log Type = 01
Log 4B - Health 0000 - HlthDtl 0000 - Time = 00:00:49 Log Type = 01
Log 48 - Health 0000 - HlthDtl 0000 - Time = 00:32:33 Log Type = 01
Log 41 - Health 0008 - HlthDtl 0001 - Time = 00:06:01 Log Type = 01
Log 27 - Health 0000 - HlthDtl 0000 - Time = 00:12:03 Log Type = 01
Log 49 - Health 0000 - HlthDtl 0000 - Time = 00:29:48 Log Type = 01
Log 4A - Health 0000 - HlthDtl 0000 - Time = 00:00:03 Log Type = 01
Log 4D - Health 0000 - HlthDtl 0000 - Time = 00:02:00 Log Type = 01
Log 39 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 22 - Health 0000 - HlthDtl 0000 - Time = 00:00:19 Log Type = 01
Log 61 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 02
Log 28 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 62 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 02
Log 29 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 63 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 02
Log 59 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 35 - Health 0000 - HlthDtl 0000 - Time = 00:10:19 Log Type = 01
Log 56 - Health 0000 - HlthDtl 0000 - Time = 00:10:19 Log Type = 01
Log 6F - Health 0000 - HlthDtl 0000 - Time = 00:00:39 Log Type = 01
Total Cert Time = 14:22:13
T>
T>
T>V4
Alternate Defect List
Num Entries = 0000 Checksum = C404
T>0D
T>
T>0DH
T>00D
T>12
PostPosted: January 22nd, 2009, 15:19
Log looks fine.
Check for bad connections on IDE connector.
PostPosted: January 22nd, 2009, 16:19
Ok, i bend PCB and it is recognize, but it seems that is Locked, HIGH, a dont remember that i put password on it..
PostPosted: January 22nd, 2009, 16:45
You can find you password in EDD7 track.
DataRecovery.bg
PostPosted: January 22nd, 2009, 17:00
is this it?
PostPosted: January 22nd, 2009, 18:16
Nope
PostPosted: January 23rd, 2009, 1:03
Location: Zagreb,Hrvatska popravljam diskove "bussy,0LBA" http://www.hddrepair.dzaba.com/
I have no problem to learn, where can i find docs.
popust 50% na popravak bussy i 0LBA
PostPosted: January 24th, 2009, 11:50
What do u want to learn?
PostPosted: January 25th, 2009, 5:49
Could anybody write down how to get track above through terminal? Thanks.
PostPosted: January 27th, 2009, 10:13
how to i read this track to obtain my password?
Users browsing this forum: ad1479 and 68 guests
