 Post subject: Maxtor DiamondPlus unexplained failure
PostPosted: January 21st, 2009, 6:36
After having completed the tranfer of two HD from one computer to an identical one, one of the two HD at the switch on burned out. The HD is a Maxtor Diamond Plus 8, an ATA/133 unit. At power switch-on the chip carrying the green led went afire and blew. I'm quite sure I did not mess up with the power connector since I did this several times before. and have a good familiarity with my PCs. I doubt the culprit is the controller because the second disk, that I connected as a slave to the sanme data cable, behaved correctly.
Since the disk contains important data and I believe they are still on the platters , I would like to know if I can restore the HD functionality by replacing the PCB (assuming I can find an HD twin....)
Any help will be wellcome...
File comment: the failed chip can be seen in the top right of the picture, close to the power connector.
 Post subject: Re: Maxtor DiamondPlus unexplained failure
PostPosted: January 21st, 2009, 6:39
That burn might have damaged pre amp. Also firmware might be bad as a result of an incorrect write to the disk service area during burn. The data is easily recoverable by a pro. If its important, seek pro help.
PostPosted: January 21st, 2009, 7:11
I have an identical (B8FEA) PCB for sale if you want to try that.
PM me if interested.
PostPosted: January 21st, 2009, 7:47
If you have 2 identical drives, why not transfer PCBs to determine electronics?
PostPosted: January 21st, 2009, 7:52
who doesn't have any of these to sell. :lol:
PostPosted: January 21st, 2009, 8:13
I have pcb. And can recover data if you need it.
PostPosted: January 21st, 2009, 8:16
I have a drive for you to recover your data to if your interested? :lol:
PostPosted: January 21st, 2009, 8:28
I have your data already and a pcb. PM me for good 'Asda' price. :lol: :lol:
PostPosted: January 21st, 2009, 8:32
Game over. Data already sent via pm plus a free N40 P. Teletransported.
PostPosted: January 21st, 2009, 8:33
lol :lol:
PostPosted: January 21st, 2009, 8:46
hddguy wrote:
lol :lol:
Thats LOW.
I thought I had that sale in the bag. :wink:
Users browsing this forum: Google [Bot] and 61 guests
