 Post subject: Swap PCB of IC25N080ATMR04
PostPosted: January 21st, 2009, 15:48
I have a IC25N080ATMR040 it doesn't spin up.
After changing PCB it spins up but no drives are detected.
Original PCB
> 14R9060
> J41063D
> N13452
> OFGD
Donor PCB.
> 14R9060
> J41063D
> N1XXXX
> XXXX
As I understood SA Information ist keept in NVRAM.
I thougt last task to restore data would be to copy NVRAM.
What can I do to copy "NVRAM" ? What tools can I use.
Sould I solder the NVRAM. Can it be erased while soldering???
Is there another possiblity?
Regards,
FastClick
 Post subject: Re: Swap PCB of IC25N080ATMR04
PostPosted: January 21st, 2009, 16:07
You can move NV RAM if you have good reworking skills. You can read/write nv ram with expensive tools. Also with expensive tools you don't need native NV RAM and can still recover data.
Give this to a pro if its important. Should be cheap enough if you dont do anything else to it. If you lose NV RAM chip or damage it then the price will be a lot more.
PostPosted: January 22nd, 2009, 6:45
Okay some more question
1. If a "pro solder" destroys original NVRAM while solding/desolding. Does that means everything is lost?
2. Is there another way. Sending Both PCB to someone doing the job?
PostPosted: January 22nd, 2009, 7:01
1. Lost for you. Not for me.
2. Possibly. Ask someone local.
Users browsing this forum: shubhsinghal and 65 guests
