 Post subject: My Seagate HDDs Are they safe ?
PostPosted: January 23rd, 2009, 6:22
HI,
i have two seagate hard drives.
ST380215AS
ST3500320AS (new Firmware flashed SD1A (validated one) )
So the thing is the hard-drives some times act fuzzy as far as booting is concerned. i have ubuntu on my other hard-drive
I have saved logs from HDDLife and CrystalDiskInfo
They give slightly different perspectives about it. But that only adds to my confusion :oops:
Also my 3500 has been recently replaced. i had bought it in november last year.
So is it safe to use these hard-drives.
Is it possible that there is some problem with the SATA cables instead of the hard disk. This is because i had installed Ubuntu and put a lot of stuff in it after 4-5 hrs and then the 3500 crashed. figured out it was a firmware issue but i'm not really sure, can somebody please tell me more about this ?
HDDlife.log [2.83 KiB]
Downloaded 559 times
CrystalHDD.txt [7.55 KiB]
Downloaded 608 times
 Post subject: Re: My Seagate HDDs Are they safe ?
PostPosted: January 23rd, 2009, 10:12
what did u mean when u are talking " and then the 3500 crashed".... not detected? some strange sound inside or what?
PostPosted: January 23rd, 2009, 12:24
Ubuntu's files got corrupted. Not entirely crashed. BUt file errors on Ubuntu.
Infact Ubuntu froze while normal operation, and then upon reboot certain files appeared corripted. Some checks failed. I think it happened after i flashed SD15A but i dont know what is happening.
I inter-changed the SATA IDE cable and now both of them work. But i'm wondering how long :S
PostPosted: January 23rd, 2009, 13:49
The best way , to u be safe should be u use a soft like MHDD; Victoria,etc and did a scan sector test, if tests sucess u will be so safe because , Media could be OK, SA too , and MHA too the " HDD engineering its working " , because its identified the engineering zone showing all information "Model, ID; LBA, Size , etc" and was able to did the complete surface and the hdd its answering to the "ATA command" , so could be FS problems on a logic level situation, and discard physical problems
Users browsing this forum: Google [Bot] and 92 guests
