 Post subject: REPAIR WITH SHOCK: SAMSUNG HD204UI
PostPosted: March 8th, 2015, 6:12
My SAMSUNG HD204UI had didn't spin.
i realise that's head stuck issue.
i pray :please: and beat up the disk after power connection.
and disk starts and spin.. :D :horse:
but i have many disk like that. Seagate's never fix by shock therapy.
what can i do for these disks?
Motor is locked. i open the cover. screw driver couldn^t any move.
must i transport the platter to good one for data recovery?
which numbers must the same for two disks?
 Post subject: Re: REPAIR WITH SHOCK: SAMSUNG HD204UI
PostPosted: March 8th, 2015, 7:25
You had luck with the samsung....
Now if you cant do that with a seagate i suggest you to stop playing around and dont open tour drive or your data is toast.... you need to take tour drive as is to a data recovery company
PostPosted: March 8th, 2015, 13:06
Spildit wrote:
Good luck with the shock therapy and please don't go near any important hard drive :)
+1
Data Recovery Pakistan
PostPosted: March 8th, 2015, 15:28
Spildit wrote:
By this post and the other user posts i think that most likely this user is trolling.
:shock: :shock: :shock:
If not he is attempting to repar "many drives" that possible are for clients using .... shock method !
So now i'm in shock myself and will no longer reply to posts of this sort.
Oh man! I am from Turkey.
We know all type of dressage. :wink:
Head stuck could easily fix by that method. There are many example.
One smack does not damage to disk.
one hand to other hand.
But motor stuck is a very big problem for me.
PostPosted: March 8th, 2015, 18:21
Don't forget that smacking the drive HARD on a hard concrete surface will eliminate 99% of the problems.... :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Did I go too far!!!!!
PostPosted: March 9th, 2015, 4:51
The funniest post ever! xD The solution for your problems is shocking! :lol: :lol:
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
PostPosted: March 9th, 2015, 17:45
The disk reads many data app. %90
but some bad sector appears at %80 scan of hddtune
i don't know when bad sectors occur. because i don't know the disks history.
i think it could be at head stuck time. head wants to move but it couldn't.
probably the last head of disk damages. or some bad sector occurs on platters.
i count 5 bad sector and scanning stops.
this is back-up disk of a hospital. it works all day. 7/24
PostPosted: March 9th, 2015, 17:49
you knows shock therapies saves life often.
this is back-up disk of a hospital. it works all day. 7/24[/quote]
PostPosted: March 10th, 2015, 11:11
Now try to do the same with a a new seagate and see what happens faster... xD
PostPosted: March 11th, 2015, 22:59
Try throwing it in on a blender. :P
PostPosted: March 12th, 2015, 7:37
I think it will brake the blender...
PostPosted: March 13th, 2015, 2:39
Not unless if the blender's made from Nokia 3310s, or if you shoved the HDD in an industrial grinder. :lol:
Users browsing this forum: Google [Bot] and 171 guests
