PostPosted: November 27th, 2003, 16:37
Hi all
I have a Hitachi Notebbok drive giving me a trouble
It is recognised in the bios but fails to read.
it has also lost all referance to the serial number.
is this a bad module? and if so any ideas on how to resolve the problem?
The PCB is fine and tested oK.
Cheers :)
PostPosted: November 28th, 2003, 3:38
heads
PostPosted: November 28th, 2003, 3:59
Password on it?
PostPosted: November 30th, 2003, 7:34
Malcolm wrote:
Hi all
Cheers :)
Heads will be ok... I have recovered data from these drives easily. I am sorry that I cannot give specifics to my recovery technique..... Maybe you can use Hot-swap??
Bye
PostPosted: December 6th, 2003, 9:11
guru wrote:
Malcolm wrote:
Hi all
Cheers :)
Did you have any success with your Hitachi drive?
Regards,,
Guru
Bye
PostPosted: January 11th, 2004, 22:19
Happy New Year All :)
Yes I did thank you Guru HS did the trick
Now I am trying to get my head around toshiba MK4018GAS Series notebook drives that are failing to mount
any ideas?
PostPosted: January 12th, 2004, 7:48
any ideas?
Hehe Toshiba eh! Nice drive ....... Yes typicaly problems will either hang PC or just not mount. Can't swap PCB , important data on it, linked to the de! Maybe try hardware clone and not PC based. Thats all I can say... :teeth:
Bye
PostPosted: January 12th, 2004, 19:37
Malcolm, how did you do the HS? Thanks.
PostPosted: January 12th, 2004, 21:12
Head exchange is pretty easy on most 2 1/2 inch drives. If they have load/unload ramp it's a simple process :D
Bye
PostPosted: January 13th, 2004, 4:33
HD2003: HS != HE
PostPosted: January 13th, 2004, 12:19
Guru, thank for your reply.
What I mean by "HS" is "Hot-swap" instead of "head exchange".
Thanks again.
PostPosted: January 15th, 2004, 15:52
Thanks again.
No problems, but you will find lots of errors typicaly with hot swap.... But at least you got the data back
:good:
P.s Some drives HOt-SWAP will fuxk them up
Bye
PostPosted: January 15th, 2004, 16:20
Hi, Guru,
Sorry, I do not get it.
What is the hot swap? How do you do it?
Thanks again.
Happy New year.
:D
PostPosted: January 20th, 2004, 8:45
Hi HD2003,
I see you did not get an answer on HS
"HOT-SWAP procedure (changing the board with the power supply turned on)."
http://www.acelab.ru/products/pc-en/dtextractor.html
Do this with care and only when it is necessary.
Users browsing this forum: No registered users and 49 guests
