 Post subject: Damaged service area on WD3000JD-98KLB0
PostPosted: January 28th, 2009, 11:34
Hello all,
I have the following problem and I wanted to ask you professionals to view.
I have a damaged disk WD3000JD-98KLB0. Headers clicked when you turn on a disk loses speed.
Disk I sent to the professionals in our country (Czech Republic) and the verdict was such that the data do not save, because it has permanently damaged the service area.
I'd like to ask you professionals, whether it is possible to save data from the disk when the damaged service area.
In the event that this would be possible, I will be grateful for any contact the person who would know.
best regards
Radek HART
 Post subject: Re: Damaged service area on WD3000JD-98KLB0
PostPosted: January 28th, 2009, 11:40
I seriously doubt it is the SA that is damaged in this case.
PostPosted: January 28th, 2009, 11:45
Thank you for quick answers and there is a possibility of access to data, if the service area has been destroyed or not read?
PostPosted: January 28th, 2009, 11:47
If SA is damaged it is very hard/if possible to get the data from that drive.
If you have doubts, ship it to another firm for evaluation.
www.datarecoveryne.com
PostPosted: January 28th, 2009, 11:49
Your english is not very clear. You say hard drive clicks when powered, and by loosing speed i assume you mean the spindle motor stops? This is a symptom of head damage, but could be related to another fault, but as harddrivespecialist says, you can send to another form for a evaluation.
Has disk been opened?
PostPosted: January 28th, 2009, 11:58
I apologize for my English.
Also, I thought that head damage, but the service company claims that it is damaged SA
Disk probably was open, but the service company ...
PostPosted: January 28th, 2009, 15:06
Physical damage of SA or logical?
PostPosted: January 28th, 2009, 15:23
I'm sorry but I do not know. I am not a professional like you. I think the service area is not read.
If SA is destroyed or unreadable, do you think there is any way to read data such as reading directly from the plates?
Thank you for any advice
PostPosted: January 28th, 2009, 16:46
If SA is gone, if you have million $ to spend, yes someone can read off the platters the data - or better, is claimed to be possible. Beside rumors and bullshit, the answer actually is NO, with some very few exceptions.
PostPosted: January 29th, 2009, 15:51
Reading directly from platters? What did u got only a beautiful magnetic pattern from the media using an STM or MFM,
like this http://www.hitachigst.com/hdd/research/ ... part2b.gif or http://electron.mit.edu/~gsteele/mirror ... bits3d.jpg
but after that doesnt meaning "data" and u know data its not stored secuencially, u only could gets "-->" <---" Flux changes, " Servo Marks, GAP;ID, Sync.." etc fields only but that doesn it mean "data", should be coded after that, and to digital signal bits to bytes , and after that u got a gigiant "bytes" of all platters, and then what? u need the File system to find where the specific data starts :? ...so
PostPosted: January 29th, 2009, 16:02
In a few words : DON'T DREAM.
Ask another pro. Hope the drive was not tampered or screwed for a second opinion. And don't ask for a 100$ recovery.
PostPosted: January 29th, 2009, 21:58
I think that means MD
Happens
But I really doubt they checked SA
We did recover data from new WD drives with MD couple times but it was expensive and clients were looking just for several important files
Users browsing this forum: Google [Bot] and 98 guests
