 Post subject: SCSI drive no spin
PostPosted: May 15th, 2015, 11:30
I got 2 SCSI IBM drive that do no spin, I'm having a hard time finding a donor to swap PCB, could someone guide me what to check on the dead PCB please.
Thank you
 Post subject: Re: SCSI drive no spin
PostPosted: May 15th, 2015, 12:43
If it's not a motor jamming or stuck heads, check fuses, motor driver IC, and power converter IC's.
PostPosted: May 15th, 2015, 15:06
Solved...
PostPosted: May 15th, 2015, 15:17
Try installing the AutoStart jumper.
http://www.hgst.com/tech/techlib.nsf/te ... ghs_ps.pdf
PostPosted: May 15th, 2015, 16:12
hdd_sand wrote:
Solved...
What was the problem?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 307 guests
