 Post subject: WD5000AAKS 65TMA0 Not Detected
PostPosted: February 1st, 2009, 4:49
I'm trying to figure out what's wrong with this drive. I had this in an external drive till I knocked it off my coffee table and now it won't work. I plug it into the PC but BIOS won't detect it. (It rather say NONE it just show " " blank in the drive detection.
I don't hear typical loud clicking noise but I can hear the drive spin with very quiet clicking like noise inside then the motor powers off.... I looked the PCB inside and outside like other people mentioned in the forum, but I do not see anythging burnt.
I have a same WD5000AAKS but 65TMA0 portion is a bit different.
Thank you!!!!
 Post subject: Re: WD5000AAKS 65TMA0 Not Detected
PostPosted: February 1st, 2009, 4:53
Spindle K.O :D
-BlackST (c) 2009
PS : Possible surface scratches and head crash to surface is possible, also
My Forum
PostPosted: February 1st, 2009, 5:34
Hi cryoborgofthevenus,
If it's Spindle K.O, how can I find out?
should I place the platters in the working donor drive in a clean room? At least I do have access to the clean room.
PostPosted: February 1st, 2009, 5:45
No, it spins. So you have head stack KO and likely media damage. Plus, if you open the lid you loose alignment. IF recoverable, it's in the 2000$/EUR range. Period.
PostPosted: February 1st, 2009, 5:47
Btw If you want to hire a clean room...
PostPosted: February 1st, 2009, 5:49
Yes, place the platters in a donor. I recommend using a Seagate as a donor as they are easier to work with. :lol:
Actually only kidding, if you want to lose the data you will attempt platter swap yourself. You have more chance of getting it to work a seagate donor drive than a western digital.
be prepared to pay big bucks to recover the data. You have no other choice if data is important to you.
PostPosted: February 1st, 2009, 5:57
That "period" word is what I like from BlackST :D
@ netwalker, having access to clean room is not "the solution". This model combined with this kind of situation is a difficult task to do. Opening up drives' cover is easy, swapping headstack is easy, UNLESS that drive is WD :D (quoted from a post by Odiferous, as i recall) when unknown anomalies joined the fun....errrr....the task :D
DR pro even don't like to deal with this kind of damaged WD drives.
Spindle might not 100% K.O, unstable in my opinion. The possibility of platter misalignment after being dropped is the problem. Since this is high density drive from WD, a small drop can cause a major damage to its original condition. And, honestly, I hate myself when doing this "exhausting" alignment against WD :D
If you never do this, just don't DIY. Send the drive to DR pro near your place.
My Forum
PostPosted: February 1st, 2009, 6:02
LOL :mrgreen:
Yes, I agree. Seagate drives are rather easy to work with in this same situation
My Forum
Users browsing this forum: Google [Bot] and 113 guests
