 Post subject: Samsung HD161hj PCB trouble
PostPosted: February 19th, 2009, 9:40
Hello all i have a samsung hd161hj with the date code 2008.06. The drive clicks when powered and if the pcb is swapped the donor clicks the same. However i do not have a compatible board to put on my clients drive. Is there any way to force and older pcb to be compatible as the pcb has no rom chip.
Thank you all
 Post subject: Re: Samsung HD161hj PCB trouble
PostPosted: February 19th, 2009, 9:48
The solutions are not PCB Exchange u should be identify on first the problem, why knocks, check terminal before did anything, like "exchange" check ATA registers, etc, before u identify the problem MHA , SA, u need to plain u "route action"
PostPosted: February 19th, 2009, 17:11
Is there a way i can copy the rom from the patient pcb to a donor to make it compatible
PostPosted: February 19th, 2009, 17:27
I can fix it 100%. Pm me if you want to send it in.
Users browsing this forum: shubhsinghal and 64 guests
