 Post subject: Cheetah 10K, PCB swap
PostPosted: February 6th, 2009, 9:07
Hi
Can I transplant firmware on defect PCB of Cheetah 74GB
We have identical PCBs but solder of firmware helped not.
What is problem ? Damaged firmware ?
The defect PCB is health, no damaged protections.
How is recovareable Cheetah PCB ?
 Post subject: Re: Cheetah 10K, PCB swap
PostPosted: February 6th, 2009, 10:05
Why did u need to exchange PCB?, the hdd doesnt spin?
PostPosted: February 6th, 2009, 10:13
no, doesnt spin
PostPosted: February 6th, 2009, 10:25
Could u post u here, wich ROM did u exchange it?, if its correctly, could be its not doing correctly pins contacts with the pcb, check continuisly on each pin
PostPosted: February 6th, 2009, 10:32
the 40-pin flash chip
PostPosted: February 6th, 2009, 10:40
Are you sure the drive is not just in Spin up Disable mode?
Which is standard for SCSI
PostPosted: February 9th, 2009, 12:41
Or flash chip is bad.
Or your soldering is not that good - one pin in the air and ...
Users browsing this forum: Google [Bot] and 57 guests
