WD Essentials - possible data recovery after a fall?
May 16th, 2010, 8:22
Hello everyone, I wanted to ask a help: I have an external WD Essential (in the box there is WD15EADS 1.5 TB) 4 months old that I use for storage and then almost turned off. It fells down from a height of 50 cm (but was turned off and unplugged from the PC), now Windows XP does not detect it neither when I connect it with his box or if directly connected to the mobo, if I restart the computer it's detected at boot after a while, then after a minute gives an error message:
"4th master hard disk error
Press F1 to Resume"
But if I press F1 nothing happens. Pressing F2 the bios screen appears but the HDD is not detected. I realized that the disc spins because when I holding it in hand it swinging well, however when connected to the mobo I don't ear "strange" sounds and neither metal "ticks". I decided to try replacing the PCB with another identical, but a friend of mine told me that I should not resolve because I must at first extract the hdd firmware and program the new PCB. Can you help me?
Re: WD Essentials - possible data recovery after a fall?
May 16th, 2010, 8:31
Il firmware non c'entra nulla con le testine che si sono rotte. Fattene una ragione, c'e' da "operare" e non e' roba "fai da te"
Firmware has nothing to do with broken heads. Live with it as professional intervention is needed and is not a DIY.
May 16th, 2010, 9:06
ciao Black, ma come fai a dire con sicurezza che le testine sono rotte? anche se non si sente alcun rumore strano, nè ticchetii?
May 16th, 2010, 9:10
Fidati...
Trust me... ;)
May 16th, 2010, 9:11
Trust him.
May 16th, 2010, 11:45
sto facendo un test con GDB, che significa esattamente:
Error 27 in HD131: during ReadLBA: LBA=xxxxxxxxxxx, CHS=-1x-1x-1, Cnt=64
May 17th, 2010, 3:05
BlackST wrote:Fidati...
Trust me... ;)
Trust him he is right. Alignment, head, motor all can be the problem in this one after a fall. He knows what he is telling your. Not a DYI job on this one.
