 Post subject: no more power on the Drive?!!!
PostPosted: February 23rd, 2009, 12:49
I have a Western Digital 500GB but its not turning on anymore I feel its from the PCB
can any GURU out there help me?!!!
WD5000KS
WD Caviar SE16
Model : WD5000KS - 00MNB0
Date : 13 MAR 2006
DCM : HBHCAJCH
PCB : 2060-701383-001 REV A
but on the sticker says PCB : 2061-701383-E00 AC
 Post subject: Re: no more power on the Drive?!!!
PostPosted: February 23rd, 2009, 17:41
Be more specific.
You can feel what from its PCB? Heat? Cold? Electricity? Intoxication?
Assuming the drive does not spin, is it drawing power? Does the rest of the computer power on correctly with the drive installed?
PostPosted: February 24th, 2009, 6:06
yes its just the drive which is not getting any power so i assume that its the PCB which is burned cus the PC in on now as i speak , and i even tried it with an external SATA box and nothing happened...
thanks for the reply
PostPosted: February 24th, 2009, 8:02
Do you have a multimeter to test the PCBs components? What happened to the HDD to caus failure? Does HDD emit any strange noises when power is applied? Does BSY light show when HDD is attached to MHDD?
PostPosted: February 24th, 2009, 9:50
actually the HDD does nothing when power is applied ... there is no noise nor heat on the PCB
and i dont have multimeter to test the PCB components
so wat can i do in such case?!!!
PostPosted: February 25th, 2009, 19:39
ask Marc, he is from Belgium:
member5963.html
Users browsing this forum: Google [Bot] and 191 guests
