 Post subject: heads compatible? ST
PostPosted: January 23rd, 2009, 14:17
Hi gurus! :mrgreen:
PATIENT HD 80GB
DONOR HD 120GB
LOOK PHOTO...
Нет ничего невозможного
 Post subject: Re: heads compatible? ST
PostPosted: January 23rd, 2009, 15:09
Hello sempre donnor its 120gb,and u patient 80Gb (2Heads), the head map will be different, check that 80GB i had check that´s models has some tendence to head crash
PostPosted: January 23rd, 2009, 16:33
Sempre, have you change heads for that model, can you post the results.
ZeBong
" Россия еще раз"
PostPosted: January 24th, 2009, 6:45
Ok! :mrgreen:
PostPosted: January 24th, 2009, 6:46
Thanks for reply my friend! :wink:
check pm
PostPosted: January 24th, 2009, 8:43
There will be a head hanging free, but it should work fine. :-)
PostPosted: January 24th, 2009, 8:44
Yep :wink: need delay time to initiate at first time when using DE
My Forum
PostPosted: January 29th, 2009, 9:13
Yes, heads compatibles!!! :mrgreen:
DE PCI it read the data, to put I am with problems to read the folder my documents…. :shock:
Help?
PostPosted: March 3rd, 2009, 10:24
Hi :mrgreen:
When making the exchange of heads I perceived superficial risks in platter side 1 next to the center to the platter. Ready HD I started date recovery and after one twenty minutes, clicking started… now sees log of the terminal
4096k x 16 buffer detected
PUMA - 1_Disk 0.07 09-26-04 14:00
Buzz - Interface task reset
Head Mask FFFF - Switch to full int.
Spin Ready
3.42 09-26-04 14:03
(P)(H)SATA Reset
AutoRd Err 43 at ffffffff.00.0002
$Switch to full int.
AM Reacquired
AutoRd Err 43 at ffffffff.01.0002
12
Initializing SMART Sectors$Switch to full int.
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
NIWOT TIME OUT
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
PostPosted: March 3rd, 2009, 10:30
I think that heads are gone.
Have you try on / off and wait some time.
ZeBong
" Россия еще раз"
PostPosted: March 4th, 2009, 14:50
I waited and I bound today continues the same with log in the terminal… :|
possible e through some command in the terminal to decide this again or alone changing heads? :?: :mrgreen:
Users browsing this forum: No registered users and 138 guests
cron
