WD800BB-53CAA0 - bios & win see it but cant read HELP!!!
March 5th, 2009, 18:56
Hi, this is an update to another post. I thought this was a drive I had that was clicking & hadn't fooled around with it in a while...No clicking - that was another WD800 i have.....
I can get bios & Win XP to see it but win says it is unreadable....can someone help??????
Bios sees it as what it is:WD800BB-53CAA0
Windows XP Pro also "sees" it...In the properties box in control panel I get this...
Disk: 0
Type: unknown
Status: Unreadable
Partition Style: Not Applicable
Capacity: 0
Unallocated Space: 0
Reserved Space :0
This drive had XP on it i believe.....
Can anyone help me out there? Software ideas? DOS ideas...anything?
Thanks!!!!!
Re: WD800BB-53CAA0 - bios & win see it but cant read HELP!!!
March 5th, 2009, 19:31
Most certainly you have a firmware problem on your drive.
You need some special tools to solve it, so if your data is important, send it to a DR company.
March 6th, 2009, 1:50
Zero LBA this style , test it on another pc - if the result is the same the drive need to be serviced. No sw will revive it.
March 6th, 2009, 2:29
Test it with mhdd, see if it sees capacity.
If mhdd sees full capacity, test with testdisk
