 Post subject: Replacement PCB required for Maxtor SATA HD
PostPosted: March 22nd, 2009, 13:11
I have a damaged PCB on a Maxtor Maxline 111 7L250 So 250GB sata HDD which I need to replace. Three questions:
Is the replacement of such a board straight forward - i.e simply screwing the new on on or does it require specialist tools?
Does any one know of a UK supplier? The PCB is labelled Sabre/ Sata/ ROHS with the No 302006101
Any help would be appreciated.
-Angie
 Post subject: Re: Replacement PCB required for Maxtor SATA HD
PostPosted: March 22nd, 2009, 13:32
I'm down the road, in Peterborough.
Post a hi-res pic of the damaged PCB.
PostPosted: March 22nd, 2009, 14:14
Thanks. :-) I've taken a photograph, I hope it's clear enough. The part that snapped off came from the bare silver connector next to the large dark black rectangular component.
PostPosted: March 23rd, 2009, 6:47
I can almost certainly do something for you.
PM me or msn me.
Cheers
Sean
PostPosted: April 9th, 2009, 10:21
I have that PCB if you need it, as long as the big chip on it says Oscar E5-D4 040121300. I bought it by accident when I needed the 302071101 PCB that also goes with a Maxtor MaXLine III 250GB SATA drive...
It is just as easy as replacing the PCB, as long as the drive itself isn't damaged and you get the right PCB. :-)
Users browsing this forum: Hardcore Games and 104 guests
