 Post subject: WD Files corrupted
PostPosted: April 5th, 2009, 15:36
I have WD5000aaks-00yga drive,
I could see all files and folders via DE but only some files from a folder could be opened correctly, all other files are not opened , I mean are corrupted, I started to make a copy to another drive to see what is happening, it copies normally except that there are some sectors that are marked with black in DE Map window, not green or red, I noticed that all files before the first black sector are opened normally, all other files are opened corrupted, I think we should add those defects and correct the translator, is it true?, if yes, how can I add defects , in DE I could know onlyLBA, how to know Cylinder head and number of the sector from LBA, because in the utility we could add defect by cylinder and head.
Please help
 Post subject: Re: WD Files corrupted
PostPosted: April 5th, 2009, 15:39
You should find a pro.... :D
Are you sure, the drive have good working heads, and the surface is not damaged?
Janos
PostPosted: April 5th, 2009, 16:35
YEs, the modules are good, and so the surface area
PostPosted: April 5th, 2009, 17:47
Was I talked about modules? :shock:
PostPosted: April 6th, 2009, 12:02
I bet there are shifts...
PostPosted: April 6th, 2009, 16:19
No, not true unless you want to lose your data. Try re-generating translator just using current p-list.
Users browsing this forum: No registered users and 161 guests
