erased dvd
August 21st, 2010, 10:48
I have a dvd that has been erased, and now after a quick format, I can see total capacity of 0kb.
I believe all data is still there, but how can I make an image of full dvd?
Please help.
Re: erased dvd
August 21st, 2010, 11:25
DVD erased?
Re: erased dvd
August 21st, 2010, 11:32
http://www.isobuster.com/
Download trial- see if it works- its cheap to buy. or use their new scheme to register for something and get it "free"
Re: erased dvd
August 21st, 2010, 13:11
If no joy, I can help (proprietary HW solution even if TOC is FUBAR - oh, well, until a certain extent....) but you have to send the media !
Re: erased dvd
August 21st, 2010, 13:59
I've tried IsoBuster already, and again: Windows shows capacity of 0KB, IsoBuster shows capacity of 20.8MB, and IsoBuster let me create image just for 20.8MB. Where is the rest? Why I cannot see more than that?
Re: erased dvd
August 21st, 2010, 16:39
Also try DVDisaster. It's free. Maybe it can do something.
Re: erased dvd
August 21st, 2010, 17:03
So was it erased using Quick erase or Full erase?
Re: erased dvd
August 21st, 2010, 18:20
all the sw cannot give access to physical media !
Re: erased dvd
August 21st, 2010, 18:30
pclab wrote:Also try DVDisaster. It's free. Maybe it can do something.
Common misunderstandings about dvdisaster:
dvdisaster can not make defective media readable again. Contents of a defective medium can not be recovered without the error correction data.
Such functions are outside the scope of dvdisaster's internal design and goals.
Re: erased dvd
August 22nd, 2010, 10:36
Yes, it was just a quick format.
I've just tried DVDisaster, and it doesn't work at all with my DVD.
Well, it says media is good, but cannot read any sector off it, apart from just 1 sector.
Strange.
Still I don't have access to full capacity, apart from 20.8Mb :(
Re: erased dvd
August 23rd, 2010, 6:36
Well if iso buster cannot copy the sector to iso i suggest you give Mr BlackST a try- he has some modded equipment to read the secotrs other OS does not want to.
I had RW cd that showing need to format in windows- but i recovered files ok when copy to image using isobuster.
No other software came close.
Re: erased dvd
August 23rd, 2010, 6:41
ppumkin wrote:I had RW cd that showing need to format in windows- but i recovered files ok when copy to image using isobuster.
This is because the session remained the correct size and allowed access.
Re: erased dvd
August 23rd, 2010, 8:57
romulluss wrote:Yes, it was just a quick format.
Strange.
You could cheat.
Initialize drive from another same DVD disk (сompletely filled), and сhange disks (HOT SWAP) through the top cover of drive while it is spinning. Don't use any buttoms. After that make image to file and scan it.
This method was found by us six years ago and still successfully help many times :wink:
Re: erased dvd
August 23rd, 2010, 19:33
Hehehehe :-]
There you go- now all you need to-do is find a donor cdrom- rip the covers off- dont break any plastics or it wont spin up. And be fucken careful when the cd is spinning at full speed- if that thing flies of mate- it could cut deep into your flesh!
Re: erased dvd
August 23rd, 2010, 22:18
deleted
