 Post subject: Raid 5 - 3 disks Maxtor - Mylex AcceleRAID 170 1ch, U160, 32
PostPosted: March 17th, 2009, 19:48
The board (Mylex) don't work and we would like to recover the data in another computer.
Manual -> http://www.lsi.com/obsolete/acceleraid_ ... &locale=EN . Only the block size. And install, setup the Raid.
The block (strip) size is 64 KB=128 sectors (saw several blocks of texts).
3 disks - MAXTOR ATLAS10K4_36SCA.
But I can't get the order - backward or forward.
And MBR don't have the partition info. The partition - all 000
I searched the NTFS (512 position 3). But only find in middle of disks - 1 partition.
Thank you very much for your info,
Ruy Benton
 Post subject: Re: Raid 5 - 3 disks Maxtor - Mylex AcceleRAID 170 1ch, U160, 32
PostPosted: March 19th, 2009, 12:13
Where are you based Ruy?
If the data is important on this array, seriously consider sending it to a company that knows what they are doing... Trying to fix the problem your self may make the problem worse - no offence, but you need to be very careful with critical data.
<itch>
https://www.mjm.co.uk/
PostPosted: March 19th, 2009, 16:45
<itch>
I agree. Raid 5 is not for beginners.
PostPosted: March 27th, 2009, 6:52
From another forum:
"Mylex 160 and 170 are Forward Parity Rotation and the Metadata is on the back, so offset is zero - parity starts on sector 0 of the first drive and MBR on sector 0 of the second member. 64kb is the default, but can be anything from 8kb to 1024kb."
P 1 2
3 P 4
5 6 P
and so on ... :D
"Where are you based Ruy?
If the data is important on this array, seriously consider sending it to a company that knows what they are doing... Trying to fix the problem your self may make the problem worse - no offence, but you need to be very careful with critical data."
In Portugal - Europe :lol:
I don't get the idea ... I'm working with copies (R-Studio and Winhex). What will get worse? :oops:
Maybe I don't see the light at end of the tunnel ... but that's the only thing ... or I'm missing something?
Raid 5 - any software out there ?
Since MBR is unavailable and I think NTFS is the same, please can you tell the procedure to analyze the MFT and search FILE0 and INDX data back (software, programs).
A suggestion: " ... FILE records are spread across the RAID component disks, you can deduce these parameters"
Ruy Benton
Users browsing this forum: No registered users and 60 guests
