 Post subject: Seagate vs Samsung
PostPosted: March 27th, 2009, 18:14
Are the terminal port settings the same for Samsung as they are for Seagate.
 Post subject: Re: Seagate vs Samsung
PostPosted: March 27th, 2009, 18:16
Sometimes.
Vague question = vague answer
PostPosted: March 27th, 2009, 18:22
sorry to be vague
I am using the same settings I use for Seagate terminal on Samsung and I am just getting junk displayed. Is the baud rate, data bits, parity, stop bits and flow-controll the same?
PostPosted: March 27th, 2009, 18:55
Sounds like in that case the answer is no.
There are some Samsung drives that have the same settings as some Seagate drives but I would say that the majority of them are different.
Also check your PM.
PostPosted: March 28th, 2009, 10:51
Does anyone diagnose what the problem is with this drive from this terminal report.
Samsung HD501LJ. When drive is powered up, it sounds like it is initializing properly and it comes ready in the proper amount of time. The problem is that as soon as I try to detect the drive it goes busy forever.
SPW 0000 NoLk
ADC: 0005
SpnOk
spd: 0000 0000 FFFF
H: +00000
ADC: 0006
DAC: 8088
Unlatch Tk: 000173FB
Unlatch Done
ENG>SRV>
SvoTbl Loaded
BD
0003
0004
0005
0003
0004
0006
0005
0001
0002
0003
0004
0007
0003
0004
0005
0004
0003
0001ENG>
PostPosted: March 30th, 2009, 8:24
I have a very similar problem, my terminal looks like:
SPW 1.5G LinkOk! ADC: 0003
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0004
DAC: 7C8B
Unlatch Tk: 00017967
Unlatch Done
ENG>SRV>
SvoTbl Loaded
BD
7FFF
0002
0004
0004
0004
0004
0006
0003
0005
0008
0004
0006
0002
0002
0003
0004
0004
00040401_0000_0000 ENG>
I am looking into this now, next step is HotSwap, I will post here any results.
PostPosted: March 30th, 2009, 8:32
Hi :mrgreen:
I find that it must be problem with platter, this not to obtain to read… :idea:
I wait to have helped! :mrgreen:
Нет ничего невозможного
PostPosted: March 30th, 2009, 8:54
Is this the original PCB for sure?
PostPosted: March 30th, 2009, 9:28
"Detect baud rate" command solved the most problems I had with my terminal
PostPosted: March 30th, 2009, 10:25
I performed HotSwap and could read all SA modules, I have written appropriate modules to my donor, and data is now accessible after a second hotswap, but disk clicks on access to some areas so I am now creating an image using head map. Seems to be going OK. Looks as though 1 head may be damaged, maybe the service head?
Users browsing this forum: No registered users and 341 guests
