Where would I purchase TVS Diodes?
February 16th, 2010, 20:54
Through research here I have found that simply removing faulty TVS diodes then performing recovery could easily cause data loss. I was looking to purchase TVS diodes so that instead of just removing the bad one and risking the data.
Re: Where would I purchase TVS Diodes?
February 16th, 2010, 20:58
You can replace your diode with an SMBJ12A (12V) or SMAJ5.0A (5V). These are available from Farnell, Mouser, Digikey.
February 16th, 2010, 21:54
fzabkar wrote:You can replace your diode with an SMBJ12A (12V) or SMAJ5.0A (5V). These are available from Farnell, Mouser, Digikey.
Thanks!
