 Post subject: Firmware Transfer
PostPosted: June 8th, 2011, 14:19
Hello
Some time when you use a clone PCB you have to Transfer the Firmware from the main chip or switch the main chip tot the clone PCB
How can i now when i have to switch the chip to the clone PCB or do the Firmware Transfer.
And whats the name of the tool to do the Firmware Transfer
And how i no when the main chip is the bios
Greetz
 Post subject: Re: Firmware Transfer
PostPosted: June 8th, 2011, 14:50
Depends on the type of PCB and the tools you have available. To get more clues, post pictures of your PCB from both sides!
PostPosted: June 8th, 2011, 15:12
wat is het merk en model harddisk?
Whats the brand and model of the harddisk?
Dobre
Murphy was an optimist
PostPosted: June 8th, 2011, 15:26
The question was to learn
There is no problem with a PCB
Greetz
PostPosted: June 8th, 2011, 15:28
Best thing you can do is go read a bunch of old threads then, imo.
PostPosted: June 8th, 2011, 20:00
I'm not a data recovery guy, but my understanding is that Samsungs usually don't need a firmware transfer, if the board is a good match.
Hitachis require that you move the NVRAM chip, but not the serial flash, as long as the firmware is matched.
Current Seagates, Maxtors, and WD's all have adaptive information that needs to be transferred.
Maxtors prior to the Seagate acquisition were OK with a straight board swap.
Professional tools such as PC3000 and Salvation Data's HD Doctor can save and restore the EEPROM data, as long as the board has at least some sanity. Otherwise you can use a chip programmer, either in-circuit, or after desoldering the chip.
See read-write-serial-flash-wdc-logic-boards-t7192.html
To help you identify the NVRAM, serial flash, parallel flash, EEPROM, ROM chips, you could consult my HDD IC database:
http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
WD usually assigns a circuit location with a U12 reference for the "ROMs". If this location is unpopulated, then the ROM data will be internal to the MCU.
If you still can't identify the ROM, then look for an isolated 8-pin chip. Follow its signal traces. If they lead back to the MCU, then it is probably a ROM. Otherwise, if the chip is near a coil or diode, then it is probably the MOSFET or FETKY in a switchmode DC-DC converter, in which case its signal traces will lead to the motor controller chip (eg SMOOTH).
Users browsing this forum: Bing [Bot] and 243 guests
