April 8th, 2009, 9:06
F/W need it for the above drive
DCM:DSBHCTJCH
PCB:2060-001252-000 REV A
ACE or SD
XRONIS
April 8th, 2009, 10:38
Here you go, in Salvation format.
All match apart from 1st letter of DCM.
Hope it helps
- Attachments
- wdc wd800jd-75hka1.rar
- (1.49 MiB) Downloaded 440 times
April 8th, 2009, 13:57
Thanks a lot friend...
i Hope me too
Xronis
April 8th, 2009, 13:59
any once know the XXHKXX is Caviar cyl 32 Viper family ?
Xronis
April 9th, 2009, 4:16
WD800JD-00HKA0 PCB: 2060-001252-000 REV A -> Mammoth (SATA)
U can use firmware (& PCB) from Mammoth (PATA) - of course with the same modules version
Mikippp
