 Post subject: Firmware backup on Maxtor ( etc ) hdd
PostPosted: March 13th, 2009, 19:58
Hi gurus!
How to backup a hdd firmware?
How to backup the LBA zone with bad sectors?
 Post subject: Re: Firmware backup on Maxtor ( etc ) hdd
PostPosted: March 15th, 2009, 6:32
Even if we tell you the procedure you would need special equipment to perform read/write operations on firmware like pc3000.
PostPosted: March 15th, 2009, 9:12
Thanks for your answer!
I have another problem.
When I set the safe mode on Maxtor DM+8 (lower two pins short near 40 pin '_::)
the platter spins up. Is it correct?
Maybe just the head not moving...
PostPosted: March 15th, 2009, 9:16
The situation is the same on other motherboard, and with another DM+9.
PostPosted: March 15th, 2009, 16:48
If you put maxtor in safe, the platers should not spin.
PostPosted: March 15th, 2009, 17:43
Thanks trubarevacki!
I think also. Are my jupmer settings wrong?
Or the PCB? Both?
PostPosted: April 11th, 2009, 10:11
Hi all!
Just a link for how to clone a corrupt hdd:
http://copyrsoft.com/index.php?option=c ... me&lang=en
PostPosted: April 11th, 2009, 10:48
Hi Spildit!
It is just a link for cloning methods .
The safe mode is another theme. Maybe OFF.
But, really thanks for your post.
Users browsing this forum: Pi0tR and 238 guests
