 Post subject: MARVEL FAMILY PCB BURN
PostPosted: April 17th, 2009, 10:56
Hi to all HDDGURUS,
I have a WD that the PCB is burned, and dont have same exact macthing number.
What can i do here ?
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: MARVEL FAMILY PCB BURN
PostPosted: April 17th, 2009, 11:05
What's the number on that one? Can't see it on your photo. Also that part may just be a TVS?
PostPosted: April 17th, 2009, 11:06
PCB NUMBER
2061-701552-G00 10P XT 5009 2326 6 0001440 8 441
ZeBong
" Россия еще раз"
PostPosted: April 17th, 2009, 11:12
U can remove/replace Transil D3 (SMAJ5.0A), and replace resistor R67...
Regards,
90% that's a TVS....remove it and power on..
Rgds
www.datasave.ro
PostPosted: April 17th, 2009, 13:59
The marked part is a TVS.
Remove it, and poweron alone (without the HDA) and use a FUSE in the 5V circuit.
If you are lucky the marvell mcu still good. 8)
Janos
PostPosted: April 18th, 2009, 22:40
I think you should replace it ( not remove it ) for your safety
you don't know what will happen again
maybe if you remove it and power on directly that will burn MCU
Good luck
PostPosted: April 19th, 2009, 16:30
This is why i sad, use a FUSE in the 5V line....
The TVS is only for transient filtering and overvoltage protection.
Generally it is safe to remove, but not for long use again!
Janos
PostPosted: April 20th, 2009, 10:46
Thanks to all,
I have remove the TVS and just connect the PCB and always BSY, can not also enter in safe mode.
i will try to look for a PCB donor
Anyone have this PCB
2061-701552-G00 10P
XT 5U09 2326 6 0001440 8 441
zEbONG
ZeBong
" Россия еще раз"
PostPosted: April 20th, 2009, 14:58
No no no Zebong!
You don't need same PCB
The donor PCB should match:
xxxx-701552-xxx xxx
xx xxxx xxxx x xxxxxxx x xxx
Only those 6 symbols are important for matching.
This is ABSOLUTELY EXACT information, you MUST know it, otherwise how are you still working in data Recovery???
P.S.
I've done some researches on WD and solved ABRT problem, when you have no access to userdata, but SA looks fine... :D
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: April 21st, 2009, 7:47
Creator wrote:
I've done some researches on WD and solved ABRT problem, when you have no access to userdata, but SA looks fine... :D [/color]
That´s great :)
ZeBong
" Россия еще раз"
PostPosted: April 29th, 2009, 17:25
Creator wrote:
No no no Zebong!
xxxx-701552-xxx xxx
Hi Creator,
This works in all WD disk ? or just for the marvel ?
I try this is Cyl 16 did not work :(
ZeBong
ZeBong
" Россия еще раз"
PostPosted: April 29th, 2009, 22:04
some old WD drive had this info messed up, so it might not work on old WD drives. But on old WD drives it is easy to ID the PCB by looking on layout
PostPosted: April 29th, 2009, 22:08
I wondering did somebody on this forum researched something before us :(
Sorry for these emotions
PostPosted: April 30th, 2009, 6:36
For old ones did not work, but i found a solution.
ZeBong
" Россия еще раз"
Users browsing this forum: No registered users and 64 guests
