 Post subject: MK6034GSX PCB PROBLEM
PostPosted: April 16th, 2009, 1:48
hello evryone
i have a a toshiba mk6034gsx
pcb dosent work ,
has anyone got any idea about this pcb?
please help
 Post subject: Re: MK6034GSX PCB PROBLEM
PostPosted: April 16th, 2009, 9:11
what exactly do you mean?
www.datarecoveryne.com
PostPosted: April 16th, 2009, 11:16
You need to replcase MCU onto good PCB
PostPosted: April 16th, 2009, 12:37
Or find the problem je , fuse,diode, capacitors,resistors, spindle controller, etc :D
PostPosted: April 17th, 2009, 1:27
i almost replaced all companents from a good pcb but still there is short circuit
i couldnt get rid of it untill i resloder microprocessor,
and short circut gone
i think the microprocessor has some faulty
in this case how can i recover the data( i guess i cant)
because Rom is inside the microprocessor
or do u think i still have a chance to resolder microprocessor to a good donor?
thank u for your help and comments guys
PostPosted: April 17th, 2009, 2:17
If mcu is short and you move it to another board you move the short... Very few people/companies can help you, have to send the drive.
PostPosted: April 17th, 2009, 22:20
If you have a good number of similar model pcb, tried them and if you are in luck, you may get one with correct code to work with the damaged disk.
Otherwise resoldering mcu is the only option. I think this one need BGA rework.
Users browsing this forum: Google [Bot] and 109 guests
