 Post subject: About an HFS+ partition
PostPosted: April 23rd, 2009, 6:24
Hello again! I'm trying to recover an HFS+ drive and the file table seems to be 99% deleted (after full scaning with most of the available softwares I get either none or only 7 folders and 16 files). There are thousands of lost files and they are OK, but the customer wants them in their folders because of the requeriments of his system. Has the HFS+ got another copy of the file table, and where is it? The EFI partition is all gone and the first few million sectors of the volume (after the HFS+ signature which is still there with the volume bitmap, at sector 2 hundred thousands something) are all 0x00.
Thank you.
 Post subject: Re: About an HFS+ partition
PostPosted: April 23rd, 2009, 8:13
Hola!
Is this a Mac partitioned drive?
Are you mounting it in a Mac, PC or Linux box?
Is there sector damage to the drive or has the partition become corrupted?
Have you imaged the drive yet?
PostPosted: April 23rd, 2009, 11:00
What software are you using on it currently?
PostPosted: April 23rd, 2009, 15:00
I'm working with WinHex, R-Studio and UFSexplorer, mainly. No bad sectors, and I've imaged the drive already. From sector 0 to 6,000,000 the drive is all set to 0x00 except for sectors near 523,000 - 526,000 which have some HFS+ partition information (the volume bitmap or equivalent, and the partition volume header, but no catalog file or file table). It's from a NAS working under MAC, but I'm trying to recover it with a Windows PC.
But, anyway, I think HFS does not save any copy of the Catalog File.
PostPosted: April 23rd, 2009, 15:25
I would suggest taking a look at it with diskwarrior and/or data rescue. Sometimes the non-mac native tools have a harder time with HFS in my experience.
http://developer.apple.com/technotes/tn/tn1150.html
Everything you ever wanted to know about hfs+
PostPosted: April 23rd, 2009, 17:00
Thanks Steve, I've already read information in that website. It doesn't say in a explicit manner that there's no copy of the catalog file, it just says where the catalog file is and how does it work, all about Binary Trees... but as I said, I think there's no copy of it. Thanks drccsc, I'll try diskwarrior.
PostPosted: April 23rd, 2009, 17:11
Don't bother your arse with DiskWarrior, waste of time IMO. DataRescueII is your best bet.
Data Recovery Ireland
PostPosted: April 24th, 2009, 0:49
I do agree that data rescue is probably better than diskwarrior. But I've had diskwarrior do well from time to time.
PostPosted: April 25th, 2009, 3:29
Give a try to Stellar info's MAC recovery software V3.0.
I am using it for about 6 months and got better results compare to Data Rescue II.
Regards,
PostPosted: April 25th, 2009, 9:31
Regards,
I bought Stellar, used it a few times, and then never again.
What do you like about it?
Jon
http://www.datasaversllc.com
PostPosted: April 25th, 2009, 9:32
It depends upon what you are using DiskWarrior for. It's not a data recovery program, per se - it fixes directory issues, and does a fine job of that. Directory repair is (or should be) part of the data recovery process.
Jon
PostPosted: April 26th, 2009, 5:09
Regards,
Jon
Which one did you use: V. 3.0 under OS X or V.2 under windows?
If V.2.x, then I agree with you. It was not so good.
Stellar V3.0 does better job in finding HFS+ lost partitions and reconstructing file system.
The bad thing is that, it is too slow.
regrads,
Pninja
PostPosted: April 26th, 2009, 10:34
I only used Stellar for Mac. I don't recall if it was 2.0 or 3 but I know that I upgraded to 3.0.
It took forever to reconstruct the directory. The folders that if found were empty and a big waste of time. There are much better tools out there, IMHO.
Jon
PostPosted: April 26th, 2009, 21:55
Assuming if this is the MAC file system, to get back the correct data info, Datarescue will not work. You can forget about Stellar MAC, it only works when you have min system damage and in that case, you do not need it anywhere.
I think you are going in wrong direction.
As it is a NAS, the underlying FS need not be MAc. Most of the time, it is some linux variants.
You probably need to try some ubuntu or debian linux to mount the volume and extract data.
PostPosted: April 27th, 2009, 3:25
I have no doubt it's entirely working under MAC, the Volume Header (and the Alternate Volume Header) is still there as I said, and it reveals a partition which holds the whole logical space...
And there are no Linux I-Nodes nor MFT records anywhere. And I would not get good RAW data if it were a Linux FS because of the "13th block" for files larger than some tens of kB.
PostPosted: April 27th, 2009, 3:44
Try UFS explorer.
PostPosted: April 27th, 2009, 3:57
HDD Spaz wrote:
Try UFS explorer.
Already done, thanks.
PostPosted: April 27th, 2009, 9:25
I have used Nucleus for Mac with some success. Give it a try in demo mode.
Kernel Mac data recovery software tool is a Window OS based Apple Mac Data Recovery utility, recovers data from the mac hard drives, external devices (Zip, Jaz, Syquest), digital camera cards, Apple iPods and much more & performs apple mac recovery. Kernel Mac data recovery software is compatible with Mac OS X and OS 9 (Classic).
One downside was if the folder or filename contained an invalid character like / ? # \ the recovery utility would come to a stop. It just couldn't filter them out whilst recovering.
Users browsing this forum: Google [Bot] and 75 guests
