 Post subject: Corrupted MYOB data file repair
PostPosted: April 24th, 2009, 22:46
Hi guys
I have recovered MYOB .MYO file but its corrupted, has anyone attempted repair on this file and successful?
Thank you.
 Post subject: Re: Corrupted MYOB data file repair
PostPosted: April 27th, 2009, 0:54
i have seen a utility form a company on the net which i think was available from USA
cant remember the name, but if you google myob recovery you should find it
PostPosted: April 27th, 2009, 3:37
Hi cre, yeah many utils that recover those files but not fixing the corrupted files.
PostPosted: April 27th, 2009, 4:13
Depending on the kind of corruption you have in the file it may be possible to extract part data from the file
I had an article from myob about the process I will try and look for it tomorrow
Did you try the file verify utility in myob
I had a case very recently that said file was corroupted and could not open it and said contCt myob for help with this . I found out that even though I recovered the file from the faulty drive it only recovered part of the file as opposed to the entire file. I did another recovery on the drive got the full size and all was ok, maybe check this or see if there is a myob backupfile on the drive still
Users browsing this forum: No registered users and 84 guests
