 Post subject: The data of Firmware was damaged.
PostPosted: April 26th, 2009, 17:28
HDD MODEL:HDS728080PLAT20
The data of Firmware understands and it has been understood that there is breaking.
I am embarrassed.
Where is software that can edit Firmware of ServiceArea of HDD?
 Post subject: Re: The data of Firmware was damaged.
PostPosted: April 26th, 2009, 17:55
You need sw + hw complex Like PC3000 to access to the drive SA wich is on the platter.
More info:
results-the-yourself-solutions-t11912.html?hilit=results
Janos
PostPosted: April 27th, 2009, 1:41
ハードドライブがどんな状況でトラブルを起こしたのですか?
まずFWを書き直す前にハードドライブの何処が悪いかの確認はしましたか?
もし自分での修理をとお思いでしたらロシアからPC3000か中国からサルベーションの機材を購入しないと修理はできないと思いますよ。費用的には100万円を超えると思います。
How did your drive die? Before you rewrite the FW, did you check everything else to make sure the FW was the problem? If you are thinking about fixing on your own, you might want to get the PC3K or Salvation tools. You might be looking at over $10K...
Users browsing this forum: ad1479 and 63 guests
