SnapServer Data Recovery Tool?
May 7th, 2009, 20:40
Hi All,
I have a Snap Server with 1 disk in it, it appears it's using it's own SnapOS file system. If anybody knows of any software or data recovery tools that may be able to view the contents of the disk please let me know by Private message.
I suspect the NAS box is faulty but the disk appears to be fine.
Thanks,
Zed
Re: SnapServer Data Recovery Tool?
May 7th, 2009, 21:23
just did a job on a netgear nv+ with failed enclosure and was able to get all data back with rstudio, possibly try this one and see how it goes.
May 7th, 2009, 21:28
Check you pm. One of the three solution should work for you. Good luck
May 7th, 2009, 21:30
rstudio do not work well on Snap. No harm trying but my experience so far is negative
May 7th, 2009, 21:46
Meow
any chance you can PM the solution also just for future use in case.
thank you
May 7th, 2009, 21:59
Sure. Already pm.
