 Post subject: Looking for someone to recover data - UK preferred.
PostPosted: April 30th, 2009, 12:00
I have a Seagate Barracuda 7200.10 320GB disk that has been damaged when the wrong power supply was plugged in. I've located an identical disk / PCB (see attached photo). The red area on left PCB is where the original PCB is damaged. The disk /PCB on right is the new one. Bottomline is I would like to get the data off the disk. I put the new donor PCB on the old disk but did not help as, although drive now spins up, I cannot see it in BIOS. I believe the ROM chip needs moved from blown PCB to new one but I don't have the skills.
I really need someone with the requisite skills to recover the data either by moving the ROM chip or whatever is required. I live in Edinburgh, Scotland but can ship if you are skilled and would like the business or can recommend a reputable company. I would need an idea of cost first.
Many thanks.
 Post subject: Re: Looking for someone to recover data - UK preferred.
PostPosted: April 30th, 2009, 12:02
PM me, I'm in Peterborough.
I'm sure Sean aka PCIMAGE will be able to help you.
PostPosted: April 30th, 2009, 12:04
Now that's what I call timing!!!
PostPosted: April 30th, 2009, 12:07
I'm in Herts :)
https://www.mjm.co.uk/
PostPosted: April 30th, 2009, 15:33
place your bids, cheapest quote get's to swap the ROM chip :)
Users browsing this forum: No registered users and 96 guests
