 Post subject: Seagate Help???
PostPosted: May 11th, 2009, 15:31
Hi Gurus!!!!
I can see everything on the HDD but when I copy them, I get files filled with 0s
This is what I got... Do I need to repair CE Log, remove the CE Log or other issues???
Interface task reset
4096k x 16 buffer detected
MERCURY - 1_Disk 8.03 04-20-05 14:16
Head Mask FFFF - Switch to full int.
Spin Ready
8.03 04-20-05 14:22
(P)PATA Reset
Master
AT Er 00 Nwt Er 37 RdWr 00e1f.03.0053
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: f21078ef ba f21078ef.0.0d8 0395 f5a5 00d8 0395
AutoRd Err 43 at 000e1f.03.0053
CE Log EC=37 Rtype=5 OV=0 STStatus79
Add to Pending 3aaaAT Er 00 Nwt Er 43 RdWr 00e1f.03.0054
AutoRd Err 43 at 000e1f.03.0054
CE Log EC=43 Rtype=5 OV=0 STStatus79
Add to Pending 3aabAT Er 00 Nwt Er 43 RdWr 00e1f.03.0056
AutoRd Err 43 at 000e1f.03.0056
Add to Pending 3aacAT Er 00 Nwt Er 43 RdWr 00e1f.03.0057
AutoRd Err 43 at 000e1f.03.0057
/T
T>
:5000000003000003 AX`3LG1MQA2' "000000000000"0CAB0-0CBDB
SRAM Ovly = Diag
 Post subject: Re: Seagate Help???
PostPosted: May 11th, 2009, 17:56
This error continues all the time ? if its its an autoselft test from seagate, trying to add sectors to the pending list, u could tried to manage it that, with "hardware control" or tried another options, but if u dont have experience with that the best its send to a proof DR Company
PostPosted: May 11th, 2009, 20:11
Yes this is the screen from the autoselft test from seagate when I power on...
I guess it will be the SD tool time.
Any other thoughts on this error?
Read is very very slow but also, won't let me copy anything. I can copy files but all files are filled with 0s with right filename and right file size.
PostPosted: May 12th, 2009, 6:04
Thanks Splidit,
Got it fixed!!!!!!!
Users browsing this forum: Google [Bot] and 51 guests
