 Post subject: Firmware Request: WD3200BEVT-00ZCT0
PostPosted: May 18th, 2009, 4:37
I'm looking for the FW for
WD3200BEVT-00ZCT0
Date: 22 DEC 2007
Thailand
Thank you in Advance!!!
 Post subject: Re: Firmware Request: WD3200BEVT-00ZCT0
PostPosted: May 19th, 2009, 22:48
Here you go.
http://files.hddguru.com/download/Non-PC-3000%20firmwares/Western%20Digital/WDC_WD3200BEVT-22ZCT0.rar
PostPosted: April 13th, 2011, 13:00
Nice... but what do you do with this firmware?
I mean, how to load it?
Thank you, I'm newbie with this kind of drives.
As a matter of fact, on the label there is one item called DCM: HBCT2BNB
What does it stand for? Looks some kind of sub version, isn't it? Thank you for any clarification.
Cor
PostPosted: April 13th, 2011, 13:03
Hard drives don't work like that; you don't just "load" firmware
Generally, firmware copies are traded here to give pros a reference to use when repairing damaged firmware on other drives that have the same version
PostPosted: April 13th, 2011, 13:09
Ok I have what looks like a firmware issue.
The drive is not clicking. Spins up correctly.
After a while you hear the heads moving and (looks like) reading something, then some pause and then again (looks like) reading something. This repeats unfinished.
But it is not a head clicking.
Any idea? tip? what is the DCM: value in WD drives?
Does it makes sense to find the drive board?
Thank you
Cor
PostPosted: April 13th, 2011, 13:46
Could be lots of different things. You should send or take the drive to a pro for a diagnosis.
Users browsing this forum: Google [Bot] and 60 guests
