 Post subject: WD10TMVV short pin?
PostPosted: March 4th, 2011, 23:06
Anyone have a pic or know which pin to short to bypass SA reading and become ready? I assume this is possible like the older WDs.....
 Post subject: Re: WD10TMVV short pin?
PostPosted: March 5th, 2011, 11:33
How do you propose the drive should get ready if it does not read the SA?
PostPosted: March 5th, 2011, 11:52
I presume the OP refers to shorting the read channel, a process that used to be used to get the WD electronics to report on readiness which was a useful method of repair in certain circumstances. Can the OP confirm?
PostPosted: March 6th, 2011, 0:31
Correct. That is precisely what I am trying to do.
PostPosted: March 7th, 2011, 16:03
TV9, TV10
PostPosted: March 7th, 2011, 19:01
Kernel Mode? Safe Mode?
PostPosted: March 11th, 2011, 3:22
unknown20010 wrote:
TV9, TV10
Thanks. I will test this out on a reference device. I appreciate it.
Users browsing this forum: Majestic-12 [Bot] and 57 guests
