 Post subject: Should I trash this TOSHIBA MK8032GA?
PostPosted: May 19th, 2009, 17:43
Hi, I own an external USB-drive within this 80 GB TOSHIBA MK8032GA. Unfortunately it makes funny "brrrzzz, brrzz" -sounds at certain stages.
I am no expert and have no skills in Windows, since I use Macs or Ubuntu. Nevertheless I managed to run HDDScan for Windows version 3.0 from the M$-partition of my internal laptop drive.
All in all 182 bad blocks have been found, quite some in an area @ ca. 39%. (Please notice the graphical results depicted at the bottom of this post)
Can I straighten this device somehow by the use of software? Thanks in advance for hints and advices. :D Cheers
Model: TOSHIBA MK8032GA
Firmware: AD00
Serial:
LBA: 156301488
Report By: HDDScan for Windows version 3.0
Report Date: 5/19/2009 10:17:20 PM
Executing
Block start at 0 time 434ms
Bad block found, start LBA : 7656960
Block start at 7657216 time 2843ms
Block start at 17281024 time 214ms
Block start at 17283072 time 480ms
Block start at 17283584 time 236ms
Block start at 17285888 time 213ms
Block start at 17286400 time 235ms
Block start at 17287168 time 180ms
Block start at 17287680 time 168ms
Block start at 17288448 time 203ms
Block start at 17289216 time 269ms
Block start at 17289728 time 225ms
Block start at 17290496 time 146ms
Block start at 17291264 time 325ms
Block start at 17292032 time 202ms
Block start at 17292544 time 280ms
Block start at 17293312 time 257ms
Paused
Executing
Block start at 60437504 time 75ms
Block start at 61459712 time 1692ms
Block start at 61460224 time 457ms
Block start at 61460992 time 1126ms
Block start at 61461504 time 157ms
Bad block found, start LBA : 61461760
Block start at 61462272 time 3447ms
Bad block found, start LBA : 61462784
Block start at 61463040 time 4801ms
Bad block found, start LBA : 61463552
Block start at 61463808 time 2804ms
Block start at 61464064 time 1417ms
Block start at 61464320 time 556ms
Bad block found, start LBA : 61464832
Block start at 61465344 time 1682ms
Block start at 61466880 time 778ms
Block start at 61467392 time 2691ms
Block start at 61467904 time 85ms
Block start at 61468160 time 554ms
Block start at 61468672 time 591ms
Block start at 61469184 time 470ms
Block start at 61469952 time 302ms
Block start at 61470464 time 269ms
Bad block found, start LBA : 61470720
Bad block found, start LBA : 61471232
Block start at 61471488 time 2850ms
Bad block found, start LBA : 61472000
Block start at 61472512 time 279ms
Bad block found, start LBA : 61473280
Bad block found, start LBA : 61473792
Block start at 61474048 time 2884ms
Bad block found, start LBA : 61474304
Bad block found, start LBA : 61474560
Bad block found, start LBA : 61475072
Block start at 61475328 time 2836ms
Bad block found, start LBA : 61475584
Bad block found, start LBA : 61475840
Bad block found, start LBA : 61476352
Block start at 61476608 time 2823ms
Bad block found, start LBA : 61477120
Bad block found, start LBA : 61477632
Block start at 61477888 time 2873ms
Bad block found, start LBA : 61478400
Block start at 61478656 time 2858ms
Bad block found, start LBA : 61478912
Bad block found, start LBA : 61479168
Bad block found, start LBA : 61479680
Block start at 61479936 time 2847ms
Bad block found, start LBA : 61480192
Block start at 61480448 time 8166ms
Bad block found, start LBA : 61480960
Bad block found, start LBA : 61481472
Block start at 61481728 time 8281ms
Bad block found, start LBA : 61482240
Bad block found, start LBA : 61482752
Block start at 61483008 time 2876ms
Bad block found, start LBA : 61483520
Block start at 61483776 time 2917ms
Bad block found, start LBA : 61484032
Bad block found, start LBA : 61484288
Bad block found, start LBA : 61484800
Block start at 61485056 time 2841ms
Bad block found, start LBA : 61485312
Bad block found, start LBA : 61485568
Bad block found, start LBA : 61486080
Block start at 61486336 time 2841ms
Bad block found, start LBA : 61486592
Block start at 61486848 time 9562ms
Bad block found, start LBA : 61487360
Bad block found, start LBA : 61487872
Block start at 61488128 time 9604ms
Bad block found, start LBA : 61488640
Bad block found, start LBA : 61489152
Bad block found, start LBA : 61489408
Bad block found, start LBA : 61489664
Bad block found, start LBA : 61489920
Bad block found, start LBA : 61490176
Bad block found, start LBA : 61490432
Bad block found, start LBA : 61490688
Bad block found, start LBA : 61490944
Bad block found, start LBA : 61491200
Bad block found, start LBA : 61491456
Bad block found, start LBA : 61491712
Bad block found, start LBA : 61491968
Bad block found, start LBA : 61492224
Bad block found, start LBA : 61492480
Bad block found, start LBA : 61492736
Bad block found, start LBA : 61492992
Bad block found, start LBA : 61493248
Bad block found, start LBA : 61493504
Bad block found, start LBA : 61493760
Bad block found, start LBA : 61494016
Bad block found, start LBA : 61494272
Bad block found, start LBA : 61494528
Bad block found, start LBA : 61494784
Bad block found, start LBA : 61495040
Bad block found, start LBA : 61495296
Bad block found, start LBA : 61495552
Bad block found, start LBA : 61495808
Bad block found, start LBA : 61496064
Bad block found, start LBA : 61496320
Bad block found, start LBA : 61496576
Bad block found, start LBA : 61496832
Bad block found, start LBA : 61497088
Bad block found, start LBA : 61497344
Bad block found, start LBA : 61497600
Bad block found, start LBA : 61497856
Bad block found, start LBA : 61498112
Bad block found, start LBA : 61498368
Bad block found, start LBA : 61498624
Bad block found, start LBA : 61498880
Bad block found, start LBA : 61499136
Bad block found, start LBA : 61499392
Bad block found, start LBA : 61499648
Bad block found, start LBA : 61499904
Bad block found, start LBA : 61500160
Bad block found, start LBA : 61500416
Bad block found, start LBA : 61500672
Bad block found, start LBA : 61500928
Bad block found, start LBA : 61501184
Bad block found, start LBA : 61501440
Bad block found, start LBA : 61501696
Bad block found, start LBA : 61501952
Bad block found, start LBA : 61502208
Bad block found, start LBA : 61502464
Bad block found, start LBA : 61502720
Bad block found, start LBA : 61502976
Bad block found, start LBA : 61503232
Bad block found, start LBA : 61503488
Bad block found, start LBA : 61503744
Bad block found, start LBA : 61504000
Bad block found, start LBA : 61504256
Bad block found, start LBA : 61504512
Bad block found, start LBA : 61504768
Bad block found, start LBA : 61505024
Bad block found, start LBA : 61505280
Bad block found, start LBA : 61505536
Bad block found, start LBA : 61505792
Bad block found, start LBA : 61506048
Bad block found, start LBA : 61506560
Block start at 61506816 time 9524ms
Bad block found, start LBA : 61507072
Bad block found, start LBA : 61507328
Bad block found, start LBA : 61507840
Block start at 61508096 time 9536ms
Bad block found, start LBA : 61508352
Bad block found, start LBA : 61508608
Bad block found, start LBA : 61509120
Block start at 61509376 time 9507ms
Bad block found, start LBA : 61509888
Bad block found, start LBA : 61510400
Bad block found, start LBA : 61510656
Bad block found, start LBA : 61511168
Bad block found, start LBA : 61511680
Block start at 61511936 time 9562ms
Bad block found, start LBA : 61512192
Bad block found, start LBA : 61512448
Bad block found, start LBA : 61512960
Block start at 61513216 time 9584ms
Bad block found, start LBA : 61513472
Bad block found, start LBA : 61513728
Bad block found, start LBA : 61514240
Block start at 61514496 time 9574ms
Bad block found, start LBA : 61518592
Bad block found, start LBA : 61518848
Bad block found, start LBA : 61519360
Block start at 61519616 time 9563ms
Bad block found, start LBA : 61520128
Bad block found, start LBA : 61520640
Block start at 61520896 time 2849ms
Block start at 61738752 time 299ms
Block start at 61739264 time 1170ms
Block start at 61739776 time 188ms
Block start at 61740032 time 286ms
Block start at 61741312 time 657ms
Block start at 61741824 time 1446ms
Block start at 61742592 time 2047ms
Block start at 61743104 time 725ms
Block start at 61743872 time 1669ms
Block start at 61744384 time 714ms
Block start at 61745152 time 635ms
Block start at 61745664 time 746ms
Block start at 61746432 time 235ms
Block start at 61746944 time 6259ms
Block start at 61747712 time 1113ms
Block start at 61748224 time 491ms
Bad block found, start LBA : 61748992
Block start at 61749248 time 2832ms
Bad block found, start LBA : 61749504
Block start at 61749760 time 2870ms
Block start at 61750272 time 1447ms
Bad block found, start LBA : 61750784
Block start at 61751040 time 2868ms
Block start at 61751552 time 15138ms
Block start at 61752064 time 725ms
Block start at 61752320 time 15272ms
Block start at 61752832 time 30793ms
Block start at 61753344 time 1357ms
Block start at 61753600 time 43708ms
Bad block found, start LBA : 61754112
Block start at 61754368 time 2898ms
Bad block found, start LBA : 61754624
Bad block found, start LBA : 61754880
Bad block found, start LBA : 61755392
Block start at 61755648 time 2850ms
Bad block found, start LBA : 61755904
Bad block found, start LBA : 61756160
Bad block found, start LBA : 61756672
Block start at 61756928 time 2883ms
Bad block found, start LBA : 61757184
Bad block found, start LBA : 61757440
Bad block found, start LBA : 61757952
Block start at 61758208 time 2963ms
Bad block found, start LBA : 61758464
Bad block found, start LBA : 61758720
Bad block found, start LBA : 61759232
Block start at 61759488 time 2800ms
Bad block found, start LBA : 61759744
Bad block found, start LBA : 61760000
Bad block found, start LBA : 61760512
Block start at 61760768 time 2817ms
Bad block found, start LBA : 61761024
Block start at 61761280 time 9770ms
Bad block found, start LBA : 61761792
Bad block found, start LBA : 61763072
Block start at 61763328 time 2943ms
Bad block found, start LBA : 61763840
Bad block found, start LBA : 61764352
Block start at 61764608 time 2843ms
Bad block found, start LBA : 61764864
Bad block found, start LBA : 61765120
Block start at 65654784 time 58ms
Bad block found, start LBA : 65655296
Block start at 65655552 time 2859ms
Bad block found, start LBA : 65656064
Bad block found, start LBA : 65656576
Bad block found, start LBA : 65657856
Block start at 65658112 time 2860ms
Bad block found, start LBA : 65658624
Bad block found, start LBA : 65659136
Block start at 65659392 time 9623ms
Bad block found, start LBA : 65659904
Bad block found, start LBA : 65660416
Block start at 65660672 time 9693ms
Bad block found, start LBA : 65661184
Bad block found, start LBA : 65661696
Block start at 65661952 time 2863ms
Bad block found, start LBA : 65662464
Bad block found, start LBA : 65663744
Bad block found, start LBA : 65664256
Block start at 65664512 time 9535ms
Bad block found, start LBA : 65665024
Bad block found, start LBA : 65665536
Block start at 65665792 time 9650ms
Bad block found, start LBA : 65666304
Bad block found, start LBA : 65666816
Block start at 65667072 time 2798ms
Bad block found, start LBA : 65667584
Bad block found, start LBA : 65668864
Bad block found, start LBA : 65669376
Block start at 65669632 time 9712ms
Bad block found, start LBA : 65670144
Bad block found, start LBA : 65670656
Block start at 65670912 time 9719ms
Bad block found, start LBA : 65671424
Bad block found, start LBA : 65671936
Block start at 65672192 time 9691ms
Bad block found, start LBA : 65672704
Bad block found, start LBA : 65673216
Block start at 65673472 time 2838ms
Bad block found, start LBA : 65674496
Block start at 65674752 time 9993ms
Bad block found, start LBA : 65675776
Block start at 65676032 time 10102ms
Block start at 87834880 time 749ms
Block start at 90081536 time 71ms
Block start at 91892992 time 18188ms
Block start at 106814720 time 104ms
Block start at 108962048 time 82ms
Block start at 110200064 time 50ms
 Post subject: Re: Should I trash this TOSHIBA MK8032GA?
PostPosted: May 19th, 2009, 17:54
Backup and scrap this for what it is worth. Common problems include spindle motor bearing and head problems on this model.
Data Recovery Ireland
PostPosted: May 19th, 2009, 18:58
Yes.
If you wanted to try anything, you could try zerofilling the drive and seeing if that helps. But in this case I would be very surprised if it did.
PostPosted: May 19th, 2009, 22:58
How valuable is your data. Data = very important = back up = trash drive and buy new
Iorana Haraharaini
PostPosted: May 20th, 2009, 5:26
A new drive , much larger, is less than 50 EUR. OR ask a pro near you , if he has the possibility, to SELFSCAN the drive (he knows, if he's a real pro). If the drive PASSES you have a fixed drive, if not, it will likely die or stay as is, but doesn't hurt and it will cost you few bucks.
PostPosted: May 20th, 2009, 17:18
I would think that even asking the question means the drive should be scrapped. Drives are inexpensive, recovery isn't.
Shawn
PostPosted: May 20th, 2009, 17:59
Shawn
I agree with this.
PostPosted: May 21st, 2009, 5:26
you could low level format the drive
but there why to many errors on that drive and will become unstable :(
scrap it keep the board that all
PostPosted: May 21st, 2009, 5:34
@craig6928
LLF will fix maybe a CRC bad block but won't solve servo or degraded format condition , only selfscan can fix it. And not always, indeed. Anyway it's worth a try.
Users browsing this forum: Google [Bot] and 43 guests
