 Post subject: Help with damaged ST3300620A (Seagate Barracuda 7200.10)PATA
PostPosted: May 20th, 2009, 9:19
Have here one HDD ST3300620A (Seagate Barracuda 7200.10) PATA 300GB.
Attached and applied power.
Spins up and does irregular "whip-clunk".
HDD not detected.
Perusal of HDD shows damage on PCD, probably physical.
See image attached.
What part is this ? Is this a passive element (coil) ?
Can it be fixed by replacing or soldering.
Drive is only to spin for imaging and will be scrapped afterwards.
Thanks in advance, /pipedevnull
File comment: Damaged section marked with circle/arrow.
 Post subject: Re: Help with damaged ST3300620A (Seagate Barracuda 7200.10)PATA
PostPosted: May 20th, 2009, 9:34
The PCB is fine , only some top part of the ferrite coil is cracked. Your problem is most likely heads or physical damage INSIDE. Call a pro.
PostPosted: May 20th, 2009, 9:57
Part number of Ferrite Coil is unknown, no ST3300620A to salvage at the moment.
Is this an actual ferrite or just an air coil in enclosure ?
If it is a ferrite coil, the main section of the housing is still available.
So soldering should probably fix this, the housing itself appears to be commonly employed plastic/ceramic with no significant electrical properties.
CF: "internal damage" ... The drive was _NOT_ dropped, jarred, jostled etc.
The damage very probably results from a second drive's screw scraping over the element.
NO internal damage to be expected.
Any suggestions to potential problems related to specifically this PCB-component ?
/pipedevnull
PostPosted: May 20th, 2009, 9:59
You are wasting time. If the coil was damaged or not working, the drive won't spin at all. Internal damage can happen anytime anyway.
Can't tell you more.
PostPosted: May 20th, 2009, 10:09
Wasting time ? - Maybe yes, maybe no.
Internal damage ? - I will see.
Again: coil appears intact, the solder connection is ruptured.
What's the part number ?
What coil ferrite or air-coil ?
/pipedevnull
PostPosted: May 20th, 2009, 10:11
These coils cannot be bought easily; you should take one from another Seagate.
Its a ferrite coil, not air-coil.
Dobre
Murphy was an optimist
PostPosted: May 20th, 2009, 10:14
Ah ! Thanks.
Do you possibly know the number of the coil ? -
The "writ" on the top of it should suffice.
I happen to have quite a few dead Seagate's around,
just not specifically this ST3300620A 300 GB Model.
Thanks in advance.
/pipedevnull
PostPosted: May 21st, 2009, 16:08
PostPosted: May 21st, 2009, 16:43
BlackST,
Let Pipedevnull do DIY and break the drive finnaly.
When he open the HDD he will call you :D
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: May 22nd, 2009, 1:22
Sit and wait... "yes we can" :mrgreen:
PostPosted: May 28th, 2009, 8:07
Haha. - Open Drive.
Yes, indeed. If it need be, I'll open the drive in the Clean-Box I happen to have here.
Probably just by accident it appeared at some time in the past.
I somehow cannot remember - maybe I was abducted by aliens, you know :D
I happen to have repaired quite a few things in my life ... not only harddisks,
but that is of no interest.
Coming back to the drive.
Coil reconnected, drive spins beautifully and is accessible via a Tableau eSata Bridge.
Addressing sectors etc. is no problem.
Data delivered is reproducible.
Next Question:
What actual function does this coil (cf. image at beginning of post) have circuit-wise ?
Does anyone have reliable information about the characteristics of this coil in operation ?
Any pointers to addtl. documentation, circuit-diagrams or the like are greatly appreciated.
Google or like ilk deliver too much garbage to get anything out of it.
Special thanks @dobrevjetser (too bad, you don't have a rating system here AFAIK)
for relevant information.
/pipedevnull
P.S.:
I have frequently and repeatedly visited this board for years now.
Remarkably, though, the general attitude of some participants definitely changed over the last 1 1/2 years.
Seemingly the board appears to have experienced a notable increase of people exhibiting severe smugness, rather than a more community-like attitude, to which I personally am much more comfortable with.
Having valid, reliable and hard experience in HW, SW, IT, signal-processing, repairs, etc. for over 30 years now, this actually begins giving me a slightly negative impression.
Of the posted answers to this thread (six), only two actually were indicative, the others rather non-constructive.
This singular thread delivers an effectivity of 2/6 = 1/3 = 30% potentially helpful answers, but 60% were actually non-constructive.
1 was basically correct, but off the point
1 was a null answer (considered a bump)
2 were off-topic
Hm.
PostPosted: May 28th, 2009, 9:31
There is no published docs on drives PCBs
I guess this coil is part of the power supply for preamp
PS: You got really lucky
PostPosted: May 28th, 2009, 9:53
pipedevnull wrote:
P.S.:
2 were off-topic
Hm.
You're correct about the insufferable arrogance of some of the posters here. I used to visit this site much more often than I do now but have lost patience with the silliness. I am a big believer in Ockham's Razor: the correct solution is often the simplest one, viz. when you see an obviously burnt component on a PCB it would seem rather obvious to attempt replacement of that part before sending it off to a "pro". Good general rule of thumb: quality of advice offered is inversely proportional to total number of posts. There are a few exceptions here but it seems to hold true fairly often. Congrats on solving the problem.
Users browsing this forum: Majestic-12 [Bot] and 169 guests
